What is the fault
My Reebok RB1000 exercise bike seems to be consuming batteries. With a fresh set of 4 C cell batteries, the bike screen powers on and I can adjust the resistance. However if I leave the bike for a week or so, it will have depleted those batteries. There are no noises from the bike when not in use, nor is the screen on.
History of the fault. Did this happen suddenly?
Simply the battery went (after about 2 years of it being in), so I replaced the 4x C batteries where it worked perfetly but upon coming back to the bike a week later it was completely dead. So I assumed the batteries were faulty, put some new ones in and guess what....worked perfectly until a week later.
Actions unspecified in the manual
None
Other:
I have opened up the top display and the component on DZ1 has some darker lines around it, but this is the only component of it's size on the board, so maybe just normal.
Equally there is a loom that connects to the back of the display and runs down to the motors. I thought I found the fault as I could see some frayed wires, but cutting the insulation back it just seemed to be a random set of loose frayed wires that run down the inside of the insulation. This has definitely not broken off anywhere in the loop, as all the other wires are complete.
None
Other:
