Tam/WB2TT
Is this what you mean: connect a cap from one side of existing transformerlegg said:Or the separate lower-current diode/capacitor rectifier from the same
winding of the main transformer. Will give the same 17V but this is
loaded only be regulator and predrivers, so droop is avoided on the
regulator control and predriver supply, allowing the same low
saturation from pass elements without added magnetics.......
to cathode of diode. Anode of diode to +17V. Second diode with its anode to
cathode of first diode and cap. Cathode to filter cap with ground end of
that cap to +17V? Gives ~34V.
Tam
