Reading 74HC165 through parallel port? (schematic included)
Bart T.
This problem is driving me nuts! I'm using a 74HC165 shift register
and am simply unable to properly read the data using the parallel
port. Writing data to it works smoothly but receiving the output isn't
working and I believe it's something to do with the electrical
characteristics of the parallel port status lines.
My schematic is at: http://www.trzy.org/pport.jpg
Here's the problem: When the connection between PAPER_OUT (the status
pin I'm using to receive input) is broken, the circuit seems to work
fine. The first 4 bits that are read back are the same as were
written.
However, if the connection is made, after the first 1 appears on the
output pin, it seems to "stick" for the remaining output cycles
(though sometimes it goes low for a cycle.) What could be wrong? I've
tried a lot of things with no luck at all.
Some examples:
Wrote 0x5, read 0x7
Wrote 0xA, read 0xF
Wrote 0xC, read 0xD
Wrote 0x8, read 0x9
Wrote 0x4, read 0x3 (?!)
Things I've tried to troubleshoot this:
1. I tried breaking the connection when I knew the output should be 0
(to see if the parallel port was driving it high somehow) but it
remained at 1! I'm using a multimeter to test this. The voltage on the
parallel port PAPER_OUT pin (when disconnected and left floating) is
always 0, I've never seen it change. Even if I don't actually perform
the read operation in my C code, the problem persists!
2. I disconnected the 165's output from the parallel port and then,
when the output was 0, I made a connection to +Vcc (+6V in my set up.)
The voltage went high but as soon as I removed this new connection, it
returned to its actual state as it should. This doesn't happen when
connected to the parallel port.
3. I've tried writing both 1 and 0 to the status port (in software)
before sampling the input. It didn't have an effect.
4. I've confirmed that the chip is not bad.
In summary:
The circuit does not work if Q7 of the 74HC165 is connected to any
input pin on the parallel port. Removing this connection will not fix
the problem until the 165 has new data written to it.
Has anyone successfully used the parallel port to read back data from
a circuit? I've seen one design that used transistors but I'm afraid I
don't understand why they were necessary. I've seen some designs that
don't do anything special and they work fine. I really think my design
should be fine.
Rune Christensen
Hello
You need to use 5V as vcc because the parallel port is a 5V circuit.
Cheers
Rune
Rune Christensen
Hello
You have to make sure that the parallel port is set to SPP mode in the
BIOS.
What operating system are you using?
Cheers
Rune
petrus bitbyter
Bart T. said:
written.
Some examples:
Wrote 0x5, read 0x7
Wrote 0xA, read 0xF
Wrote 0xC, read 0xD
Wrote 0x8, read 0x9
In summary:
should be fine.
At a first glance I see no flaw in your schematic, so I believe it is either
the hardware of the printerport or the OS you're using that sets you up.
Have a look at
http://www.beyondlogic.org/
There's everthing you need to know about setting and programming the
parallel printer port.
petrus bitbyter
Z
Zorknob
Is the ground of your circuit tied to the parallel port ground? They
must be tied together for this to work.
Change your VCC supply to +5V. Although the HC165 can handle +6V, it
is at the high end of the spec. In addition, with a 6V VCC, the
logic output high level is too high for TTL inputs.
Bart T.
Rune Christensen said:
Hello
BIOS.
It is set to SPP mode already (where the data register is used for
output only and the status register is for the input.) I'm using an
old Windows 95 machine.
The actual voltage supplied by my 4 AAA battery setup is ~5.6V. This
is still within the valid range of TTL so it should work, shouldn't
it? The logic IC datasheets I've seen for various TTL 74 series chips
show that 6V is acceptable.
The circuit is grounded to the battery's negative terminal (the
parallel port ground pins are grounded there too, otherwise the
circuit won't work of course.)
Bart T.
Yes. The ground rail on my breadboard is connected to the parallel
port ground as well as the negative terminal of my power supply (AAA
batteries.)
~5.6V is actually supplied -- is this really too high? The port seems
to be able to read individual 1's and 0's this way (I poked around
with other parts of the circuit.) If it was just a matter of it being
too high, I would imagine that it would simply cause problems on the
parallel port side. But as it is, the 74HC165's internal state seems
to be corrupted (because removing the connection while shifting out
bits does not ensure that the succeeding bits are correct.) How can
out-of-range voltages cause this bizarre effect?
I can try breaking down the voltage to 5V using resistors but that'll
have to wait until tomorrow evening when I can get the supplies.
Are there any other possible causes?
One thing that came across my mind was that if a 1 appeared on the
output pin, some interference would somehow cause the clock signal to
pulse (even though they're physically not very close.) If you look at
my schematic, I'm only writing the high nibble whereas the low nibble
is always 0xF. An extra clock tick would cause 1's to be shifted in,
hence 0x5 turns into 0x7 and 0xA to 0xF but it doesn't explain 0x4
turning to 0x3 or 0xC to 0xD. I guess the only thing I can think of
now is that the internal state of the 165 is somehow being corrupted
by the interaction of the Q7 output pin going high and the parallel
port (note that the parallel port itself is not forcing the line low
or high, I've tried test that.)
Lewin A.R.W. Edwards
batteries.)
Have you got adequate bypass caps on the chip? I have had somewhat
similar problems with 'HC373s, which were caused by poor PCB layout.
(I didn't believe this could POSSIBLY be the cause, given the low
speeds... but it was).
Bart T.
When you say "bypass" caps, is that the same as decoupling capacitors
connected between Vcc and Gnd of the IC? I use 0.1uF for that purpose.
I don't doubt that these HC devices are very sensitive to interference
on the clock lines and in general picky about things because I've
heard several people say that, but I had an earlier circuit (of which
this troublesome HC165 was the final output stage with the only
connection to a parallel port status pin) consisting of 3 HC ICs (an
HC164, an HC273, and the HC165) where the first 2 ICs worked
perfectly. My current circuit works just fine if there is no
connection from Q7 to the port. That's what seems so strange to me. If
the connection is present when a high bit is sent out by the 165, it
seems to ruin the internal state of the 165 (it persists after the
connection is removed and the 165 has to be reloaded with new data.)
Thanks a lot to everyone who has replied :) It's greatly appreciated.
David L. Jones
written.
Some examples:
Wrote 0x5, read 0x7
Wrote 0xA, read 0xF
Wrote 0xC, read 0xD
Wrote 0x8, read 0x9
In summary:
should be fine.
Have you checked the input rise and fall times with a CRO?
74HC chips have a maximum rise/fall time spec, if you exceed it you
can get all sorts of WEIRD problems.
The capacitance of your connecting cable can cause problems like this.
Keep your cable as short as possible and check the lines with a CRO.
Dave :)
Bart T.
I don't have access to an oscope, unfortunately :( But I did make some
progress today:
I built a voltage divider out of 10K and 2.2K resistors I had handy to
bring the Vcc down to just under 5V. However, as soon as the parallel
port is connected, the voltage drops to 2.3V. I never experienced a
noticable voltage drop when just using the full potential of the
batteries.
But on the plus side: The chip works! I didn't even have to add RC
filters to the clock and parallel load lines, though future designs
will use them.
When I unplugged the batteries completely, the circuit still
functioned! The 2.3V Vcc seems to be coming from the parallel port
though I have no idea how. The outputs of the port are only connected
to the clock line and the data lines and the only connections to the
power rail are through data input lines (because I'm keeping them
high.) It's as if the Vcc is being supplied by 4 of the 165's data
inputs! I know the voltage divider idea isn't really suitable for a
final design but I'm still wondering why it isn't working as it
should. I'll try rebuilding the circuit from scratch tomorrow. I might
just have to buy a 5V battery or use the PC as a power source for my
prototypes.
Thanks for the help so far! I'll keep plugging away at it to see if I
can make it work the way it ought to with external power.
Chris
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
tronnort@yahoo.com (David L. Jones) wrote in message
some progress today:
to bring the Vcc down to just under 5V. However, as soon as the
parallel port is connected, the voltage drops to 2.3V. I never
experienced a noticable voltage drop when just using the full
potential of the batteries.
will use them.
connected to the clock line and the data lines and the only
connections to the power rail are through data input lines (because
I'm keeping them high.) It's as if the Vcc is being supplied by 4 of
the 165's data inputs! I know the voltage divider idea isn't really
suitable for a final design but I'm still wondering why it isn't
working as it should. I'll try rebuilding the circuit from scratch
tomorrow. I might just have to buy a 5V battery or use the PC as a
power source for my prototypes.
I can make it work the way it ought to with external power.
You might also try using a 7805 (a voltage regulator) to get a perfect
5V with up to 100mA (in the case of 7805) or 1A (in the case of
78H05) available. Just chuck a couple of capacitors between Ground
and Vout for filtering. Vin (according to the data in front of me)
can be anywhere from 8V to 40V.
Chris
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBEl4AgxSrXuMbw1YRArB4AJ40wWnaZksGS2xHbPJcoitVq4tJQgCfX+0W
4/jlC6e4KXOT0h0YQ9rS9MM=
=6ZyW
-----END PGP SIGNATURE-----
