Re: Internal wiring of USA v UK mains plug
G
Gary Tait
[email protected] wrote in @q69g2000hsb.googlegroups.com:
I dont see how. Cooking fire risks certainly differ by socio-economic
group, but I dont think electrical fire risks vary much. Things are
perhaps different in the US.
The way I see it:
The lower classes see thmselves more as DIYers, even if they are bad at
it.
The lower classes generally cannot afford to have out of date electrical
upgraded to modern standards, so try to bodge what they have to
something they feel is useable, sometimes with disasterous results.
G
Gary Tait
Helps ?
It must be easier learning Japanese than learning to differentiate all
that lot and then ominously on top of that sections marked "Reserved
for Future Configurations"
Is it subsets of that lot for each state or each utility company or a
total mish-mash ?
They are named with a spec code that electricians learn, which is pretty
simple (first digit pertains to the voltage/terminals, the second
amperage).
Not like BS and CEE numbers which directly mean nothing, although I think
one could boil those 30 down to about 5.
G
Gary Tait
Eh? Even with final circuit rings there were at least three types of
sockets. Normal, D&S (round pins where the live was a removable fuse) and
Walsall gauge. Same as 13 amp but the pins at 90 degrees. The last two
often used by councils on housing estates. Gawd knows why. Some official
with a bee in his bonnet. Or saving pennies.
Then plenty of the old types still in use. 3,5 and 15 amp round pin. In
both 2 and three pin. Then there were some oddities with flat pins.
I know of these:
Special plugs for computers servers and other IT gear. They have a T
shaped earth pin.
I think it is some variation of BS546 used for theatrical lighting.
Then there is all varieties of CEEKon fittings.
US visitors used to laugh at our variety of sockets, domestically. Now we
have only one, and they have the variety.
Not really. Domestically, for GP recepticals, there is only the the one
basic standard with a few minor variation, all backwards compatible to
the parallel blade two prong plug.
G
Gary Tait
There is no such thing as an *EU* plug.
Technically likely not. But there is a two round pin plug that will fit
into most of Europe's sockets, and the CEE7/7 (AKA Shucko) which will fit
into a subset of those.
Dave Plowman (News)
I can see that a modern three pin socket might accept older plugs, but the
other way round?
Dave Plowman (News)
fit into a subset of those.
There is a plug which will 'fit' but isn't up to the maximum rating of
those outlets. So really of little use.
G
Gary Tait
the other way round?
Nope, not without an adapter, which is considered by professinals
potentially unsafe, and are often used in an unsafe fashion.
I stand by the context of my original text, the lowest denominator is
the two prong parallel plug, which will fit into nearly all domestic
sockets since the 1930s. Before that the recepticals were unpolarised,
although it took until the 1970s for polarised two prong plugs to be
required on lamps and TV sets, and later some other appliances.
So, an appliance with a basic two prong plug, will fit into a two prong
receptical, a U-Grounded 3 prong vertical slot 15A receptical, and the
"T" slot 20A general purpose receptical. An unpolarised appliance with
also connect to a pre 1930s unpolarised receptical or light socket
adapter or a 10-15 receptical (whose slots were designed to accept both
angled and vertical prongs).
John Larkin
other way round?
Grab the ground pin with some pliers and twist it off.
John
James Sweet
N Cook said:
Helps ?
that
lot and then ominously on top of that sections marked "Reserved for Future
Configurations"
total
mish-mash ?
There's about 3 different types of receptacles you'll find in a US
residence, the rest on that list are either industrial stuff or obsolete
things you might find in the occasional 1950s or earlier house. Generally
you'll find mostly 15A 120V grounded types, then the clothes dryer will have
a 30A 240V receptacle and the kitchen stove will have a 50A 240V receptacle.
Other high powered items like an electric furnace, water heater, spa, etc
will be hard wired. Sometimes you'll find a 15 or 20A 240V receptacle in the
garage for something like an air compressor or small arc welder but these
are generally added by the homeowner. It's really not very complicated.
I know the UK has a number of plugs and receptacles in the same category,
I've got a small pile of various oddballs from over there right here.
James Sweet
20mA is the typical figure for our standard 30mA RCDs, but most fire
causing faults are not detected by RCD, and most properties dont have
an RCD.
But that is a separate issue to fault current discriminaiton.
GFCIs have been mandatory here for decades on any receptacle located
outdoors or within a certain distance of water, such as in kitchens and
bathrooms. Modern code is now requiring arc fault interruptors in bedrooms,
and eventually everywhere.
Dave Plowman (News)
Generally you'll find mostly 15A 120V grounded types, then the clothes
dryer will have a 30A 240V receptacle and the kitchen stove will have a
50A 240V receptacle. Other high powered items like an electric furnace,
water heater, spa, etc will be hard wired. Sometimes you'll find a 15
or 20A 240V receptacle in the garage for something like an air
compressor or small arc welder but these are generally added by the
category, I've got a small pile of various oddballs from over there
right here.
Not really. In a domestic environment anything that can't be plugged into
a 13 amp outlet will be hard wired. Including cookers, water heaters,
showers, etc. A very posh home workshop may use BS 4343 industrial types
though as some machine tools on single phase may need more than 13 amps.
Three phase domestic supplies are pretty unusual.
James Sweet
Well that's not much different than here, only difference I see is that we
have 30 and 50A 240V plugs to allow cook stoves and clothes dryers to be
high power yet not hard wired. Standard clothes dryer here is 4KW, kitchen
range is 12KW. I had a Creda dryer for a while from the UK, it was a nice
unit, but tiny and took forever to dry.
Looking through the box here... There's an IP44 plug, not even sure what
it's for, but I've never seen anything like it, looks very heavy duty, a
round pin 2 amp plug that says it's for table lamps which oddly enough has
three prongs just like the big clunky plugs, got a few of those, hmm, could
swear I had another type as well.
I like the quality of the parts overall, but these junction boxes are
*teeny*, it must be a real pain to wire them. I like the BC light sockets as
well, though they don't hold large heavy bulbs very straight.
W
Wolfi
Am 29.06.07 11.50 schrieb Eeyore:
Sure it is!
Thankfully it's one thing they haven't tried to standardise.
Here you are wrong.
The Euro plug is a flat, 2 prong, 4mm round contact plug, with pins 17mm
apart, fitting into regular 16A/240V outlets, but meant only for low power
devices. Its current rating usually is only 2,5A and they are widely used for
connecting consumer electronics (where the other end of the cable often is
pluggable too, having the 8-shape socket, if you look at it, with 2 small
receptacles 10 mm apart), small AC/DC power supplies, 240V to 2...24V
transformers and such.
They fit into the round 5mm receptacles of German type 3 contact "Schuko"
sockets, where the plug body actually dives into the outlet cover by some
20mm, allowing it to take on mechanical forces applied to the cable, rather
than having the contacts themselves deal with it.
The lack of appropriate machanical stress handling is my biggest rejection of
the American type 130V power plug system, in addition to extremely poor design
of those flat contact receptacles, which wear out very easily, giving poor
contact with all bad things to follow..
W
Wolfi
Am 29.06.07 17.59 schrieb Gary Tait:
It is "SchuKo", from german "SchutzKontakt", meaning protective aka grounded
contact, which are the 2 grooved in metal stripes at the top and bottom of the
plug housing.
W
Wolfi
Am 29.06.07 18.41 schrieb Dave Plowman (News):
Just the opposite.
The Euro plug is not designed that you can travel across Europe with your
3680W water boiler and plug it in everywhere, but for all those <= 575W
gadgets, people like to have with them, while they are travelling, but also
for devices being fully insolated, hence mot requiring the protective ground
like VCR, TV, RCR, audio amplifiers, satellite receivers, battery chargers,
etc, etc.
The Schuko outlet is rated for 230V AC to up to 20A, even though in most cases
16A breakers are used since some 3 decades.
This system is also common in Austria, Switzerland, former Yugoslavia and
Greece. I'm not sure about the Cech and Slovak Repuplic.
John Larkin
Not in my experience. I've owned houses that were first wired in the
early 1900's, and I don't recall ever having a bad wall outlet. Most
of the really old ones have been replaced, not because they failed but
rather because they had to be upgraded to accept a 3-prong plug.
A decent 3-prong molded plug, plugged into even a cheap (79 cent) dual
wall outlet, seems to be perfectly reliable. Our biggest problem is
cats chewing on the cords, some of which seem to be tastier than
others.
John
jakdedert
others.
John
I've replaced a number of two prong outlets in my house (vintage 1928)
because the outlets failed in just the manner described. I don't know
the actual vintage of the particular sockets involved--although it's
pertinent that no two were the same, leading me to believe that they
themselves were later replacements for the originals.
In some cases it was possible to easily rewired with grounded 12/2 romex
from the breaker box. In others, where that was not practical, the
two-prongers were replaced with new outlets--also two prong.
These are still available and should be used if upgrading to a properly
grounded outlet is not done.
In any case, IME the OP's statement is entirely accurate. The
edison-style outlets are either inherently--or at least 'as
implemented'--prone to losing secure contact.
jak
jak
E
Eeyore
Has meaning current ?
Absolutely not. Any 'oddballs' you have date from roughly before 1960.
Graham
