The old generators in cars required high rpms to function efficiently.
Alternators were designed and incorporated into cars specifically
because they do NOT require a high rpm to have efficient output, so you
are wrong about the 2k rpm minimum.
He is NOT wrong. At curb idle the average alternator is not capable of
producing nameplate power. Curb idle of 750RPM spins most alternators
at roughly 2100 RPM due to the pulley ratio. The BIG advantage of
alternators is that belted at 3:1, at 6000 rmp engine speed (18000 rpm
alternator speed) the rotor does not unwind itself - there is no
catastrophic separation of the commutator, and all the other nasty
stuff that happened to generators at high speeds.
Also, idiot, and wind turbine (ALL in fact) gear the blade speed up to
drive the alternator at a higher rpm. It would be no problem to convert
blade rotation into a higher rpm shaft drive.
And most definitely not all wind turbines gear up the alternator. Most
of the BIG commercial units do have a gearbox - in many cases
incorporating a governor.
I do agree with you though that richardson is a dopey dumbfuck.
Something like that - yes.
