wrote in message
Just as a wild thought, if a suitable engine could be found, powering
one of those inverters with a Faraday unipolar generator and possibly
a small battery bank for overnight low loads could be a solution. The
big problem is that you would have to make the generator from scratch.
I am on mains power and this below is part of my standby set up. The other
stuff is a petrol 4.8 KW generator (single phase) and a 28 Kw diesel
generator (Three phase). I have these as I am in a cyclone prone area, and
we have been hit with severe cyclone twice in the last 6 years. We lost
power for 24 hours in one cyclone and 4 days on the other, nearer the centre
of the cyclone some were without power for around a month.
With my set up the problem would be that running the diesel 24 hours a day
would be very costly as it chews up around 73 litres ln 24 hours.
Diesel currently coast $AUS 1.56 per litre here
US gallons are around 4 litres to the gallon
UK Gallons around 4.5 litres to the gallon
Battery/Inverter
Deep cycle battery life would have to be factored into it.
I have 4 x 6 volt Trojan T105 deep cycle batteries (24 volt), here in
Australia they cost over 800.00 for the four. The first bank lasted around 4
years and I am now on the second bank purchased after the first bank failed,
they are now around 4 years old.
I have a better set of charging parameters on this set. They hardly ever get
used. I have set them up to go on charge every night for an hour. Currently
the standing voltage is 25.7 volts. The way the first set were charged I
think tended to reduce their life.
The capacity is around 225 ampere hours at a 20 amp discharge rate. They say
you can get 750 cycles out if them.
IE discharge them to 50% and that us around 2 years life if they are used
every day.
Now I have a 2 door fridge freezer and if I run that on my battery/inverter
set up it will run out of battery power over night. (Limiting the battery
discharge to 50%)
The fridge freezer draws about 2 amps at 240 volts, IE around 500 watts, now
working at 100% efficiency which it does not, that means around 20 amps 24
volts DC to drive the inverter. As we are only suppose to draw 50% out of
the batteries that means under 6 hours running time with only my
fridge/freezer running.
Actually the inverter runs around 90% efficiency, which means it would drew
more power from the batteries.
If you discharge the batteries down to more than 50% then they have lesser
life time.
As for generators, in general terms they last longer if you choose a 4 pole
genny rather than a 2 pole genny.
2 pole 60 cycles runs at 3600 RPM
2 pole 50 cycle runs at 3000 RPM
4 pole 60 cycles runs at 1800 RPM
4 pole 50 cycle runs at 1500 RPM
US uses 60 cycle power
Australia, New Zealand, England, Europe etc. use 50 cycle power .
The cycles (Frequency) is controlled by the speed of the generator.
It seems running the motor faster lowers its life.
