Hello everyone, I'm hoping you guys can help me out on a small project I am trying to build.
I have a turn table that is powered by a 12V DC motor.
I would like to build a circuit that would randomize the direct and also the run and stop time for the motor.
I would like the run time to be varied from 0 seconds to 30 seconds, the stop time to be 1 to 5 seconds, and that also to be a random variable that is always changing, and would like to be able to change the random duration.
so basically I would like the table to run forward direction for 0 to 30 seconds (random and different each time), then stop for 1 to 5 seconds(random and different each time), then when it restarts it could run forward or backwards. everything being random.
Motor direction will be controled with realys so the circuit will only have to handle energizing the coils of the ice cubes.
This all has to run off 12volts DC
If anyone has seen the cat laser towers that spin around randomly that is kind of what I'm looking for but I need a pause between direction change due to turning mass on the table
Thanks guys,
Sparky
Thanks guys,
Sparky
