Mme Belle . . . . .
Or you could have the box held down by all of the fingers of each hand, holding around the side of each respective side of the case for stability and using a thumb or crossed thumbs to then press on the pushbutton.
The pushbutton is being mounted at center front of the side face at the front. That provides plenty of depth for the pushbutton, versus using a top mount of the switch.
If you really-really-really had your choice of choosing ANY size for those 8 player boxes sizing , what size would you want ?
Also seems like the boxes should initially be put at each player position on one teams side and then a determining of adequate elbow room and the need of 2 conductor wire length needed for connecting between side to side connections between the 4 boxes.
Then use of a longer wire to exit out of one of the 4 boxes to go over to the main unit.
THEN a replication of all of that for the other teams side.
For overall connectivity reliability and MUCH less expense . . . . use no plugs and jack sets at each box.
Instead merely use a rubber grommet inserted in case side to pass the wire thru and then use an UNDERWRITERS knot inside the box at the wire past the grommet, for jerk / fall / pull / strain relief.
The consideration of the space needed for each boxes circuit board build is a factor also.
I presume that the size of a box (es) sent by Most Honnable and Esteemed Oh Chosun One is being of adequate size for the MAIN unit ?.
When is your construction deadline ?
73's de Edd
73's de Edd
