Chris
I am getting 6.5 volts out of a 5v ragulator output leg. The total
input voltage is via a 6 VDC volts AC adapter. it goes into a bridge
regulator, a 100 UF cap, then into the 5 volts regulator. At its
input jack - I am reading 10.72 voltage ( WTF, the adapter its rated
as 6 vdc output, ? ) , then at output side of the voltage regulator, I
am getting 6.72 volts.
I dont quite understand it as why?
The voltage is indeed dropping to 6.72 from 10.74. I thought the
voltage regulator should drop it to at least 5 volts?
I have tried two voltage regulator, and both reads the same output.
I am wondering if my volt meter is defective, or if both regulators
are defective.
I cannot see wiring the regulator wrong. It has three legs. the
middle is ground. Checking the inbound first leg, it reads the full
10.72, the outbound *( last leg ) reads at 6.72
What could be going wrong here guys,?
Sorry if this question is very basic, I am just a newbie playing
around with basic tools., and a bread board. Trying to learn
Thanks to everyone in advance.
are defective.
