Well, yes and no. That's true for what is called PCM, used
on the Compact Disc and MPEG. It is sort of true for Delta-Sigma
coding, but the for the actual useful sampling rate limit, its
not really true. D-S modulation is used for the Super Audio CD.
There is no analog-equivalent of sample-rate? Then what the limits the
highest frequency an analog audio device can encode?
The circuits used. All circuits have a low-pass filtering action
of some sort. For example, 78 RPM records went up to maybe
10-12 kHz usefully, while 33s actually could go up to 40 kHZ if
pushed (e.g. discrete quad.) Many high quality audio power amps will
happily go to 100 kHZ or even a megahertz. This may be intrinsic
with the circuits, or, far more common, a simple resistor-capacitor
filter circuit.
What determines the highest frequency signal an analog solid-state
audio device can input without distortion?
The nature of the transistors is the ultimate limit. Because
at this limit nonlinearities of a rather terrible nature occur, the
circuits they are used in usually limit the frequency with the RC
filter mentioned above, or equivalent.
Analog solid-state audio device = a purely analog electronic device
that can record, store, playback, and process audio signals without
needing any moving parts.
The above device inputs the electrical signals generated by an
attached microphone. These electric signals are AC and represent the
sound in "electronic" form. Sound with a higher-frequency will
generate a faster-alternating current than sound with a lower-
frequency. A louder sound will generate an alternating-current with a
bigger peak-to-peak wattage than a softer soft.
What mathematically determines the highest-frequency electric signal
such a device can intake without distortion?
The overall design. Such things as you describe are rare, very, very,
very rare. It's very hard to STORE signals purely analog without
moving parts. In fact, I had a hard time thinking of any such
device that is or was purely analog. However, the old analog
storage oscilloscopes would meet your criteria if you don't
include electrons in a vacuum as moving parts. There the limit to the
frequency response is the size of the focus spot .... i.e.
the quality of the lenses! (Such device of course uses analog
electron lenses). If you don't intend to store forever, there
were things like analog mercury delay lines which stored signals
as sound waves travelling through mercury.
Doug McDonald
