PWM feedback
This is more of a practical question. I understand feedback and how it works and can design controllers. However, these have been for dc (non PWM) motors using tachos with a dc output.
What I want to know is how you achieve this with digital tachos which give out pulses.
I am thinking that the set point is still dc as before (or software based) and you just count the pulses from the tacho in a given time and this gives an error signal which you then generate PWM from - am I right? the rest is usual lag-lead compensators etc.
Another approach I suppose would be to have a square wave as the set-point and use the pulses from the tacho and create a phase-detector and PLL approach.
L
Lasse Langwadt Christensen
Den onsdag den 18. december 2013 21.42.31 UTC+1 skrev [email protected]:
unless you have a huge number of lines I'd measure the period of the pulses
measuring the period of the pulses and comparing to what you want the period
to be is sorta the same
-Lasse
dp
On Wed, 18 Dec 2013 12:42:31 -0800 (PST), [email protected] wrote:
Counting in a fixed window has a +-1 count ambiguity, which may cause
problems.
Usually instead of measuring frequency (counting pulses in a window)
measuring period (counting clock pulses with the sensor pulses being
the window) solves this issue if existing, one just uses a fast enough
clock.
Dimiter
You get pretty much the same effect by accepting your +/- 1 count
ambiguity (really, it's a +/- 1/2 count ambiguity), then low-pass
filtering on software. Then you're not defeating the purpose of having a
Low pass filtering = phase lag and less phase margin. So it will have to be outside the closing unity gain frequency I assume.
Yup. I'm not touting it as a panacea, I'm just pointing out that its not
necessarily all that different to do it in the digital realm vs. analog.
(Some, but not a lot, unless you really don't have many lines in your
encoder).
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Yes but you are going to have to filter it hard to get dc out of PWM. Won't you just get a sine wave with a weak filter.
josephkk
I am thinking that the set point is still dc as before (or software based) and you just count the pulses from the tacho in a given time andthis gives an error signal which you then generate PWM from - am I right? the rest is usual lag-lead compensators etc.
Back in the day ('bout 40 years ago) there were some really good frequency
to voltage converter ICs. The principles are still valid. Most digital
versions are translations of the method, pretty similar to count them up
over some fixed repeating period.
Maynard A. Philbrook Jr.
And they still exist in many venders!
Jamie
