Des Bromilow
Folks,
Has anyone assembled this kit and used it?
It went together well, but had a few issues when connecting wires
(basically the 2.5mm2 wire) fitted into the terminals, but once I
tightened up the terminals, and mounted the board on a heatsink, the
rigidity of the cables snapped the terminal away from the PCB pin.
All fixed now, but the 5K external pot is basically giving me 0 speed
for the first 15 degrees of rotation, then full speed as a sudden step -
and all around to the remainder of the pot's rotation.
I figure it will have something to do with the opamp circuits and their
voltages, but with only a DMM at home, I'm kinda stumped to find the
cause - will presevere, but looking for some experienced guys to point
me in the right direction.
Thanks,
Des
Thanks,
Des
