Presently I have an effluent pump in a remote septic tank that activates from the pump float switch. A current sensor in the house will energize a piezo buzzer indicating that the pump is running and does shut off. A normal pumpout would be around the 10 minutes.
I would like to have a system that allows the pump to shut down after about 20 minutes if the float isn't working properly or the pump isn't working properly thus saving the pump from running until it burns out ( that happened to me once) . I would then like a warning alert that the pump has failed and continue to alarm until power is shut off to the pump and float. It isn't feasible ( without much cost) to run a wire to the septic tank and float switch which would make it a more simple solution. I have attached a diagram of the present setup.
Hopefully some of you will have some ideas. Thanks.
