:On Fri, 09 Oct 2009 18:36:31 GMT,
[email protected] (Nico Coesel)
:wrote:
:>>On Thu, 08 Oct 2009 19:38:41 GMT,
:>>wrote:
:>>>>The loudspeakers each have an amplifier incorporated I repeat ... and
:>>>>each one of these amplifiers absorbs 25W, though the data sheet says
:>>>>the maximum value is 40W. The input voltage to each loudspeaker is 24
:>>>>to 48Vdc but looking at the loudspeakers specs I prefer using 48V as
:>>>You've got to be joking...
:>>>>I can't use a single amplifier because with the number of speakers
:>>>>we're dealing with it would need more then a 1000W speaker with huge
:>>>>distances involved its complicated. The source is an intercom system
:>>>>so at a first estimate 0.6mm telephone wire should suffice.
:>>>Sorry, but the only way to do this right is using 100V speakers which
:>>>are fed by several amplifiers at strategic places. There is no sense
:>>>in designing such a system. It is already available as an off-the
:>>>shelf product. Go ask at the local football stadium or an amusement
:>>>park. They deal with long distances as well. Besides, I don't know if
:>>>you want to design a safety critical system. I'd see if I can buy such
:>>>a system so I can blame someone else if things go wrong.
:>>I make a living designing these things ... so just answer my question
:>FYI: We are in the same business. I'm not saying the old way is the
:>good way and I endorse to think about new ways of doing things instead
:>of following old habbits. But in this case the 100V systems make a lot
:>of sense. I'm quite sure if you do the math on a 100V system and your
:>system, the 100V system will be 4 times cheaper and much more
:>reliable.
:OK I understand your reasoning ... but sorry I don't have as much time
:as you people do to give explanations ... There is more fun in life
:then debating on these issues ... .
:But did it ever cross your mind that it is a need of the client? Did
:it ever cross your minds that the Industry where these things are
:going to be placed have conformity issues that only the above
:mentioned Loudspeakers satisfy ... and a whole lot of other reasons
:accompany my decision.
:Martin
You post under the name of Andrew Edge yet you sign as Martin. Surely, if you
really worked at MSW Systems
http://mswsystems.com/home.htm you would have your
own email address there. Incidentally, there is nothing on the MSW website that
lists one of their services as "Public Address System Design". The stated main
areas of services are "Systems & Networking, Web Design and Business
Apllications" which says that they are merely engaged in IT design and support.
This is a far cry from the engineering requirement required for a valid company
experienced in PA system design. Of course, they could simply have failed to
enter this function in their services lsting....
I will be querying management at MSW as to your bonafides...
It is plainly obvious to anyone who is experienced in electronics that you are
not an electronics or PA engineer or anything like it. You say "you don't have
as much time (as those of us who may be competent in the field) to give
explanations", and that "there is more fun in life than debating on these
issues".
These two statements give you away as a fraudster and would NEVER be used by
someone engaged in the PA design field. In fact, they are statements more likely
to come from an uneducated juvenile out to cause trouble. Anyone who was
seriously involved with the design of PA systems, as you claim to be, would have
at the very least, a knowledge of electronics building blocks and how to select
the appropriate items for the project at hand. You plainly don't possess this
knowledge otherwise you would be pleased to describe in complex detail the
environment you have to work with and the specific problems which this
environment might present in coming to the best solution. That is the real
reason why you can't be bothered to provide explanations.
There are myriad problems in designing a PA system and there is no person on
this earth who can supply you with the answers without ALL of the specification
and details. It is a specialised field which does not really fit in with "IT
Consulting".
