I have a 3-year old Oki PS-900 soldering iron. I recently turned it off, switched to a different tip and turned it back on after which the tip would not heat up enough to melt solder. I switched back to the previous tip and it also failed to heat up enough to melt solder (although it was hot enough to create a first-degree burn.) I turned the iron off for the evening and it still failed to heat adequately the next day.
The only user-replaceable part on the iron is the coil assembly. Are there any simple tests I can do to verify that replacing the coil will solve the problem?
