Fred said:
That works, but if you add current limiting then you will need two
circuits in place of one.
In half wave, those stacked caps act as resistors of value 1/(8*F*C)
IIRC in so far as determining the average output DC voltage.
Still don't know what you're getting at. All I care about is that
electrons go into the battery. Don't care when or how. Don't care about
voltage or current. The battery sets the relationship.
Many electrons good; few electrons bad.
I want the most possible electron flow until the cutoff condition is
reached.
Think you're hung up on the classical definition of a voltage doubler
driving a classical load. That's irrelevant when you're clever enough
to stick the batteries into the middle of (what used to be a classical)
doubler.
I'd try a tilt sensor. Charge battery only when going down hill;-)
What do they use for lighting generators these days?
The one I have rubs the side of the wheel. It's a VERY noticeable drag.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted 12" LCD for Compaq Armada 7770MT.
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://
www.geocities.com/SiliconValley/Monitor/4710/
