Nathan
Hi there,
are there any good projects that use a PIC12C509?
Nathan
Nathan
Matt2 - Amstereo said:playstation mod chips (though the 12c508 is a better choice as the ps mod
chip uses little memory) and hacking optus cable boxes, there the two i
know of anyway.
www.austech.info
Nathan said:Hi there,
Nathan
Nathan said:oh ok then thanks for the tip david, ill make sure that i get a flash pic
then, na i just wanted to play around with pics in general, i guess i could
pla around with turning on and off leds and then play around with different
source codes and stuff
do you ahve any project ideas
Nathan said:they look cool, but is there anything that i can make my self i would like
to make a robot or something but without having to buy a kir or something if
you know what i mean
Nathan said:dave,
i was looking for like only circuit diagrams and schematics of circuits
online and was asking if anyone had any good references
nathan
Must be a smart cat to use a wildlife tracker.Species 5618 said:I've used a variation of this as a wildlife tracker for my cat. The RF gear
was sourced from Oatley Electronics, very small!
http://www.birch.net/~petek/rockets/RDF/70cm.html
That strange 'whooshing' noise was that last one going straight over yourSpecies 5618 said:Smart enough to lean by hiding under a corrugated iron roof the signal will
be scattered / attenuated enough to fool a 5 element yargi
