Hi Harald,
Thank you so much for your guidance. I have corrected the C2 position.
I looked at the frequency through the voltage probe. I wanted to set the output of the circuit to be at 50Hz. I really hope you can help me out.
My revised circuit below:
Please correct me if I'm wrong. To design a three phase circuit, I will need 3 identical H-bridge circuits as attached above right? Based on my research, a three phase mosfet circuit will only have a total of 6 mosfets. Does that mean I remove the p-type mosfet when connecting the three H bridge circuits together?
Thank you so much.
Regards,
KX
For this, I am not sure how I can go about doing it and how can I check the frequency of my circuit????
The frequency response of an RC lowpass filter is determined by the values of R and C and does not fluctuate and settle.
Thank you so much.
Regards,
KX
