Have a vintage Pioneer SX-1000TX receiver that the right channel doesn't seem to be working 100%. The output is slightly lower than the left channel and "thin" as best I can describe it (e.g. lacking any body to the sound). I have the schematics and have done some basic trouble shooting but at a loss where to go from here as I'm still learning about electronic/circuits etc. Here's what I've determined so far.
1) Using a old audio signal injector, I believe I narrowed it down to the Main amp unit or beyond. Initially, I thought I thought the problem was in the control amp unit where the tone controls/preamp circuitry all lie, Since it seemed like the lack of gain and lack of "body" could be related to the bass circuitry but injecting the audio signal right at Pins 2 In on the Main Amp unit (post Control Amp Unit shown in the block diagram below) still shows a disparaging difference between the channels.I was afraid to put the injector any further down the circuit as it would getting more severe of a "pop" as I moved the injector through the circuit. It's an old tube EICO Model 324 frequency generator and I'm not sure if it has the proper protection necessary or not, so I didn't want to chance it any further.Given it was designed for old tube radio diagnostics and they have much higher voltages, it probably is, but would like a confirmation from anyone that knows how far down a transistor based circuit it's safe to attempt signal injection.
2) I believe I esr checked many of caps in the main amp section (2nd schematic below), at least those greater than 10uf. Also esr'd the big 1000uf caps that follow the main amp. They all seem fine though it was done with an in circuit measure, so I realize under some cases those readings won't be accurate.
3) I measured the voltages around the transistors in the main amp circuit. I color coded those voltage readings in Red on the 2nd schematic below. I find a few interesting things from these measurements which I can't explain:
a) the first transistor Q801/Q802 in the circuit doesn't seems to react the same between the left and right channels. The right channel seems "abnormal" to me that all the voltage all around 10 volts. On the left channel, the emitter has a much higher output from the base/collector.
b) The right channels has higher voltages in general across the circuit. For example Q812 has 26.3 volts at the base, yet driven from the same 40 volts that the left channel's Q811 gets, but it's pulled much lower to 22.1 volts. I want to understand what in the circuit of the right channel could be causing that large differential. The Cap C808 failing (even though esr'd ok), One of the resistors R814,816etc out of tolerance? Diode D802 failing? Or something else in the circuit affecting it?
c) The output of this main amp unit feeds two power transistors from pins 7 & 11. On the right channel, Pin 7 (which feed q2 on the block diagram) is a couple of volts higher on the right than the left channel, yet Pin 4 (that feeds Q4) a 10th of a volt lower. I don't understand the relationship between these two power transistors, but it seems the overall voltage output for the amp is higher on the right channel, yet the signal is weaker/thinner.
4) One last item of note - The power resistor R4 that follows Q2/Q4 on the block diagram seems pretty heavily out of tolerance. Should be 330K and measures about 220K. What is the effect of that lower resistance on the circuit?
Appreciate any specific response to my questions above, as well as anything else to check for, measure etc. Obviously I want to fix this but in truth I want to learn "why" things are doing what they are doing, and what the circuit purpose is. I'm really at a beginner level in a lot of this stuff, but looking to learn and improve my diagnostic and repair ability.
