Power take off on blender?
mm
Not really electronics or home repair, but you guys seem the most
likely to know.
I have part of a Black and Decker Handy Blender, but not the model
that I found with a picture on the web. Suffice to say, it's a
blender.
And there is a mini-jack on the base, and it is in parallel with the
motor, except there is a small diode in series with the jack. So I
guess the jacke would have had about 60 volts DC. What was the
purpose of that jack?
(There is also some part I don't recognize in parallel with the
diode/jack. It looks like a small diode, but tan and partly made of
glass, and the white band is on the same end as the actual diode, and
my 9-volt digital multimeter shows the resistance as "infinite" even
on the 20 meg scale, in both directions.)
Remove NOPSAM to email me..
Tim Fischer
It takes 4 diodes (bridge rectifier) to create DC.
My guess is they sell/sold some attachment of some sort which required
power.
-Tim
David Nebenzahl
Tim Fischer spake thus:
Not true; one will produce DC, though not as effectively as either 2 (in
a voltage doubler) or 4 in a bridge rectifier.
Just as McDonald's is where you go when you're hungry but don't really
care about the quality of your food, Wikipedia is where you go when
you're curious but don't really care about the quality of your knowledge.
- Matthew White's WikiWatch (http://users.erols.com/mwhite28/wikiwoo.htm)
mm
Is this blender battery powered?
No. It plugged into the wall.
(Not just any place on the wall. There had to be an electric outlet.)
RicodJour
likely to know.
blender.
guess the jack would have had about 60 volts DC. What was the
The power takeoff is standard on KitchenAid mixers. There are a whole
host of attachments. I'd imagine the blender takeoff is similar, but
the electrical jack is a bit odd. No idea what would attach to a
blender and require mechanical power and electric.
Z
z
likely to know.
blender.
Mystery item probably a capacitor. Is it in parallel with the jack or
in parallel with the diode? I can't imagine what this setup is good
for. If I needed half wave rectified wall plug power, I wouldn't buy a
blender to get it.
mm
I'm sorry. I wasn't clear. I don't have the whole device, only the
base, but I didnt' identify any mechanical connection. Just the
electric.
Z, the diode and jack are in series with each other, and the small
unidentifed part is in parallel with the two of them together. It's
awful small to be a capacitor. It's the same size as those tiny
diodes, a mm. in diameter and 1.5 mm in length. And it has that
little bit that is clear plastic or glass.
I'll look at the Kitchen Aid appliances if they sell them in stores,
and maybe even read the insstruction manual.
Thanks.
Tim Fischer
mm said:
On 31 Oct 2006 06:54:42 -0800, "RicodJour" <ricodjour@worldemail.com>
electric.
Now I'm really confused. A blender base with no mechanical connection?
Then what is it, basically a power supply?
-Tim
H
Homer J Simpson
Maybe it's really a charger?
mm
--->> No idea what would attach to a
--->>blender and require mechanical power and electric.
It had a mechanical connection to the thing above it, that it blended.
Just none to whatever plugged into the 60 volt jack. Didn't you refer
to a possible something that had both? If not, that's what I thought
you meant.
Tim Fischer
mm said:
On Tue, 31 Oct 2006 20:44:09 -0600, "Tim Fischer"
you meant.
That wasn't me, but someone did. I think the point was that perhaps
something attached to both the mechanical connection you describe, AND the
power connection. But none of us are clear on what would need both of these
things...
-Tim
L
Lee
things...
-Tim
Back in the late 60's, a friend of mine had a blender that was a
blender, food processer, juice extractor, ice crusher, and God knows
what else. It had a whole box of attachments and heads for it. It had
enough power to dig post holes if you turned it over. I do remember
that it was made in Switzerland. It had a heating unit, (a round plate)
that dropped into the knurled collar of the blender and then the plate
with the beaters/knives sat on, then the glass jar sat on that. This
plate unit had a wire that plugged into a socket on the base.
It was used to mix and cook sauces. It even had a push button that when
depressed, would cycle the mixing while the heat was on.
I almost died when I found out that she paid over $500. for it; a lot
of money at the time.
We were living in the Bahamas at the time, and she bought it on a trip
to Miami at, if memory serves me correct, the Dade County Fair.
This was a high end product, and I believe the OP said this was a Black
& Decker.
Regards
Lee
mm
Oops, sorry. It wasn't you who asked the question. (But it was you
who snipped Rocotdjour's statement that I replied to. With his
statement in front, my statement was much more clear.)
H
Homer J Simpson
I almost died when I found out that she paid over $500. for it; a lot of
money at the time.
They sold those here for $20 at one time (not the same model?)
I recall a combination washer and dryer - what a SOB it was - and various
other combination devices. Every one was a piece of crap.
