I know my way around the inside of a computer, but am completely unfamiliar with anything using capacitors and resistors etc so am looking for some advice.
By way of explanation before I get to my question, I have an old Cambridge Azur 640H music server - basically a mini PC with supposedly high end hifi bits inside. It stores music on a hard drive. I've had it for quite a few years and have undertaken various repairs/replacements and have grown quite attached to it, and very familiar with it's internals. The unit basically comprises
Large circular mains transformer
CD unit (as used in most PC’s)
A digital-audio converter circuit board
A mini-ITX motherboard
A hard drive
Another 640H one came up for sale recently on Ebay as "spares or repairs" and fancying a challenge I bought it. Swapping bits between the good unit and the Ebay one, I've narrowed the problem down to what I think is the DAC unit which, besides doing the digital/audio conversion bit, also provides a power supply to the motherboard.(see photos below, one shows the 640H unit with the DAC unit removed, the second is a close up of the DAC unit) ).
I have done some testing (photo) and I can measure the voltage from the DAC unit to the motherboard and for the good unit it is slightly over 12 volts and for the Ebay one it is slightly less. HOWEVER For the good unit I can get the motherboard to power up (CPU fan would spin). Also the CD drive would open/close. For the faulty DAC the measured voltage varied from just under 12 volts to just over. However, the motherboard would not power up (CPU fan would give half a spin at most) and the CD drive would not operate.
The connection from the mains transformer to the DAC unit is actually 19 volts AC So it appears that the DAC unit is converting from 19 volts AC to 12 volts DC.
The second photo above shows the rear part of the DAC unit where the power comes in from the transformer. The black finned item is a large heat sink, and attached to it are 5 electrical items, each with 3 pins. Googling the part number on the item they appear to be some form of voltage regulator. My best guess is that one or more of these has failed. It's about the best guess I can come up with and makes a bit of sense, but any more educated and informed opinions would be appreciated!
Regards
Alan C
A hard drive
Regards
Alan C
