Howdy! Noob here, but long in the tooth with little experience in electronics and still trying to learn.
I picked up a multi-port USB hub. I want to modify it to use it as a charger for USB devices including smart devices (phones, pads) and regular 'dumb' USB devices. I've been reading articles on the 'Net but haven't found what I can reconcile as a definitive answer.
Here's the short of it. The hub has 13 ports. To stop any power going to data circuits, I've read that I should short the data terminals on each USB port. I plan to remove the USB cable that would attach to a computer.
The load will probably include no more than 6 smart devices at once and up to 7 'dumb' devices, total at once. My reading says that the smart devices will draw 10 volts each and the dumb devices will draw 2.5 volts each, all DC. Further, I read that the smart devices are rated at 2100 mA and the others 500 mA. The power supply that came with the hub is rated at 120-240 VDC at 50-60 Hz, 0.5 Amps and outputs 5.0 VDC 2500 mA. I don't know, but I suspect that this is not adequate for a fully loaded charger.
The question is what should the specs be for a power supply to handle the load; however, what follows is an explanation of my thinking that might demonstrate the fallacies. You will see that I'm not afraid to show my ignorance.
When fully loaded there would be a load of (6 x 10 VDC) + (7 x 2.5 VDC ) or 77.5 VDC, if the information I found is correct; however, I also found a reference saying that to quick charge an iPhone would require a 20 W or higher power supply.
I've been taught to think that batteries are rated in volts as in 1.5, 9, in small form batteries and 6 volt and 12 volt auto batteries which are meant to be used up then recycled. I have no idea about rechargeable batteries, but I would guess that the USB devices have some way to absorb as much power (voltage) as they require with some means to prevent over-charging. That leads me to believe that the batteries take in their charges over time. I also infer that the hub itself cannot tolerate too much input voltage but I don't know anything about the components on the PCB in the hub.
From Apple, I need a supply with at least 20 W for fast charging - but I'm not hung up on that as I can always charge overnight. Would I need more wattage to cover multiple devices? What about amperage? IOW, would the charger need to consider total wattage of all devices and total amperage?
I can't go any further with my limited education on the subject. I'd really appreciate it if someone could tell me how to figure it out - so I'd learn something worthwhile - and give me the end goal which is the specs for a replacement power supply, assuming one is needed.
