Thanks to all for your responses. Very helpful.
@AG- I understand what you are saying relative to the op amp circuit, however, I was trying to imagine what a dual power supply might look like- physically. If I understand correctly, as per what has been written in this thread, ( and I do have two separate variable power supplies) , if I connect the positive lead from 1, to the negative lead of the other, then I am left with one positive lead, and one negative lead, although those leads come from separate power supplies.
If that's true, I guess my follow up questions are:
1. when will that be needed. What is its advantage? And for AG specifically, if I rigged my two supplies up, how would they be useful in a distortion circuit- or would they? I think you explained it above, but I am not entirely sure what you mean. I think you are saying that if I used the two power supply thing, that I would not have to bias the o amp because the power supplies because the + lead is at 0 volts, which is half the supply voltage - so I guess we are assuming I would be using 18v total?
2.Related to question 1. When using two power supplies by linking them together, do they both always have to have the identivle voltage dialled in? What happens if they don't?
Thank-you.
