I just pulled out my old Sony ICF-SW7600G (purchased in 1994, IIRC). Now, whether using fresh AA batteries or an external 6V DC power supply, I just get a flashing "0:00" and the "Battery empty" indicator is on. If I disconnect power and remove the batteries, the flashing "0:00" continues, as does the battery empty indicator, no matter whether the power switch in is the on or off position, and this continues for some time, presumably until some internal capacitor is discharged.
The last time I used this some years ago, the DC input was a bit touchy, requiring the power jack to be pressed a bit to make good contacts. Not sure if this is an issues with those contacts, though, since battery operation is also failing.
Any suggestions for troubleshooting this, and identifying the fault?
Thanks -
Thanks -
