Power on delay circuit needed
Thomas
I need a simple 2-10second delay circuit. When power is supplied, I need it
delayed. Will a 555 delay in that manner? Needs to be simple and no
relays. Whatcha got?
Thanks in advance.
Rich Webb
Variable between 2-10 or fixed, roughly in that range?
power = ?
3 VDC, 300 mA for a flashlight bulb?
12 VDC, 200 mA to run a PC fan?
120 VAC, 1 A for a reading light?
750 VDC, 800 HP marine motor?
default
12VDC @ 100mA should do it. Thanks.
Will sinking current work? The 555 is always an option.
A simpler approach is just a NPN transistor emitter to ground,
relatively large electrolytic cap on base to ground, relatively large
resistor charging the cap from +12.
To reset the circuit quickly, a reverse biased diode to the cap and
+12 will discharge the cap faster.
Works much better with 2N7000. That's an N channel mosfet with a pin
out similar to other TO92 NPN transistors. It requires a ~4 volts on
the gate to turn on so you get a longer delay for the same RC network,
the reset diode works better, it has lower leakage.
Very handy part that 2N7000 . . . and cheap.
Thomas
With the 555, in what config would allow me to pause for x-seconds then go
high until V+ is lost?
Thanks.
