power on delay circuit
chitta
Hi
my name is chittaranjan.
I need a waveform with power on as follows
1.HIGH for 1 sec
2. LOW for 2 sec
3. HIGH permanently
Please help me obtain this waveform without using any microcontroller
Chris
Hi
1.HIGH for 1 sec
2. LOW for 2 sec
3. HIGH permanently
Read in fixed font or M$ Notepad:
| VCC
| 1uF---
| | |\ ___
| .---o---|H>O--|<--|___|.
| | | |/ 22K |
| - | |1M |
| GND GND |
| 3/6 74HC14 |
| VCC VCC |
| - | |3M |
| | | |\ ___ | |\
| '---o--|H>O-->|--|___|-o--|H>O-
| +| |/ 220K | |/
| 1uF--- 2.2 M| |
| GND |
| GND
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
Requires 1/2 of a 74HC14 (or 74C14 if you're using a power supply of
more than 6VDC), 2 1uF caps, 5 resistors and four 1N914 diodes. If
your power supply takes more than 10ms. to charge up and discharge,
you can lose the two protection diodes.
Simple, not elegant or precise. Your timing on this may vary by quite
a bit.
Good luck
Chris
