12VDC @ 100mA should do it. Thanks.
Will sinking current work? The 555 is always an option.
A simpler approach is just a NPN transistor emitter to ground,
relatively large electrolytic cap on base to ground, relatively large
resistor charging the cap from +12.
To reset the circuit quickly, a reverse biased diode to the cap and
+12 will discharge the cap faster.
Works much better with 2N7000. That's an N channel mosfet with a pin
out similar to other TO92 NPN transistors. It requires a ~4 volts on
the gate to turn on so you get a longer delay for the same RC network,
the reset diode works better, it has lower leakage.
Very handy part that 2N7000 . . . and cheap.
