Robert Baer
The inductor is made with copper wire, which is rather conductive tosk8terg1rl said:OK, so if I understand correctly: the trigger pulse ionises the Xenon,
which then becomes conducting and the main discharge from the capacitor
follows.
Depending on the circuitry of the disposable camera, the capacitor's
discharge is either controlled by a second switch, or simply by virtue
of the Xenon becoming conducting.
If it is the former, no problem - that second switch simply needs to be
triggered or replaced to bypass it.
If it is the latter, then replacing the Xenon with an inductance coil
will cause the capacitor to discharge immediately after the trigger
pulse is fired.
So in theory it should work; correct me if I am wrong please.
say the least - thereby putting a short circuit across a capacitor which
cannot charge in the first place.
As hinted perviously, the Xenon flash tube *is* the switch.
So if you want the capacitor to charge, and at some pre-determined
time to discharge into the LC circuit, you will need to add a switch
(hint: an SCR will do).
