Platforms
Content
You are correct. The NaN value means you do not use it in this application. You will notice that there are capacitors marked NaN in the same section as well.Thanks to You, I learned so much in few days and I feel that I'm getting closer to wiring part now.
No problem, You helped anyway. While it would be convenient for this moment to get results, but I would rather learn to count them myself. Problem is that either I don't know how to look for them or google doesn't offer any usable results on this topic. If You could recommend some literature about it it would be appreciated.
As far as I understood my total system impedance won't be constant (it'll change depending frequencies playing and speakers working at that moment, right?) and since my signal overlaying (I'm thinking about 120 Hz for sub-woofer, 90Hz-1100Hz mids and 1000Hz tweeter) is not that big so I shouldn't be worrying about it and leave it be, right?
I redesigned my diagram for more simple filters, for band pass I combined RL High pass and RL Low pass filters, or for High pass I should use RC filter like in tweeter?
Also getting back to question about using resistor to correct impedance for amplifier: is it legit way? Because now I counted my other speaker impedance I got it 5.333 Omh, I would like to raise it back to 8 Omh.
And last question for now: I trying to understand Chebyshev Bandpass filter and it calculation tool (not necessary I am going to use it now, but I still like to understand it), please tell me if my observations are correct.View attachment 25331 View attachment 25330
The audio guys may be able to help you with that... I can't begin to tell you how much overlap is acceptable, so I would personally build mine with no overlap. Design the filters for cut-offs at 100Hz, and 1kHz and call it done.Thank You for Your advice, I can only guess how boring is to teach beginner with no physic background since school ( I went to chemistry) but You still doing it, really appreciating it .
As for my project, I feel like I need to recalculate my tuning to frequencies overlap little less and I am good to try to wire everything together, right?
I tried this formula, in my case if mid overlaps with tweeter or sub-woofer, I get 5.33Ω. I am interested in the fact at what point this became a thing I should be concerned about. Should I avoid overlapping frequencies at all and tune all the speakers like this: sub woofer- 100Hz Mid 100Hz-1000Hz and tweeter 1000Hz since, like You mentioned before, they going to overlap anyway, but just play little bit quieter. Or I can overlap signal a bit and don't worry about impedance I get from standard 'parallel resistor' formula. It's that the case, I'm interesting there is the limit for overlaying. Are there some way to calculate, use some tables or it's jus trial and error and personal experience way?
I didn't realize you used two mids in series. That equation is correct. Your new speaker setup should have an impedance range of 8Ω to 5.33Ω, but the 5.33Ω is unlikely if the chosen cross-over frequency does not have un-impeded overlap. Additionally AT the cross-over frequency of 100Hz where the Sub AND Mids will both operate, the Inductors and Capacitors in series with these speakers will be acting as resistors, so the estimated 5.33Ω will actually be higher than expected, and would only apply in the near frequency range of your 100Hz and 1kHz cross-over frequencies.Thanks, I'll just do like You say then and don't have to be afraid that my amplifier going to burn after longer period of working. And in the future it's probably a good idea to buy amplifier with bigger impedance tolerance range, or try to combine different resistance speakers...
As for formula: I used, I believe it's the same as You posted:
R= 1/(1/R1+1/R2+1/Rn), but since my mids connected in series and I counted that they will overlap with either sub or tweeter, but not both so I got values: R=1/(1/16+1/8)= 1/(0.0625+0.125)=1/0.1875=5.333Ω
Did I used it correctly?
Looks to me like it was initially wired incorrectly as well.So I tried to wire everything together. Here are the results: leds part works like charm, they shine even with pretty low volume. I'd call it success. As for the speakers part it more or less work, but it encountered problems and raised more question.
First of all, electronic store did not have exact components I needed, so they gave close ones (in values) as needed. As a result cut off frequency got higher than I wanted (fixable with correct components).
Problem is that after wiring and testing my sub-woofer played, what I think is all frequencies, while mids and tweeter barely played at all. After quick investigation I noticed what I probably wired wrong inductors . Please take a look at my scheme and confirm is that a case.
Second (huge) problem I encountered that resistors and inductors started to overheat rapidly. Can it be because in electric store they gave me 10 W resistors? I wasn't quite sure what kind I need (my amplifier gives 40 W per channel), so I just asked to give ones vendor thinks are best (I told him my amplifier wattage). So turns out I needed 40 W resistors, or there are some kind of formula to count needed resistor wattage?
Third problem, I tried to test my theory about incorrectly wired inductors, so I rewired sub-woofer filter and quickly tested only it. As a result sub-woofer played less higher frequencies (so that proves my theory?), but I noticed that it played noticeably quieter than it should, and also resistor and inductor got really hot quick so I had to stop test. Could it be because poorly chosen resistor? View attachment 25350
