Mainlander
The gear you get to work with sometime... I have a couple of Ashton PB15
two way PA speakers that have Motorola / CTS KSN1142 piezo tweeters
(probably mounted on separate horns) and 15" woofers.
The high frequency end of the audio spectrum reproduction is very bright
and sharp. Without knowing very much about the speaker design, I know
that piezotweeters are often used without a crossover and it seems likely
to me that not enough attention has been paid to matching the speakers in
the bin so the tweeter probably has higher sensitivity than the woofer
resulting in the sharp HF tones.
I'm just looking at output EQ and whether the highs can be brought down a
little in a 1/3 octave graphic equaliser or whether the effort would be
better expended on new speakers because cheap tweeters will never sound
as good as the more expensive ones.
