Jim Thompson said:
Anyone made a synthetic candle flicker using LED's?
Usually done by blending together (AND, OR, XOR?) three squarewave
oscillators running at different frequencies. I don't like the results
though. Is there a strong source of slow (1/f) noise? Maybe FET CCS
amplified a bunch?
Ironically, this controller flickers pretty well at low bias. I'm guessing
ambient noise is enough to push it just over threshold, since there is some
hysteresis between "fully off" and "lowest duty cycle". It doesn't hurt
that vision is logarithmic so you can clearly see microamperes in the damn
LEDs (I can't probe the switch's drain waveform without the LEDs glowing a
little, and it's a 10M probe). I haven't decided yet if it's noise in the
"differential" amplifier (= two transistors and two resistors, bad CMRR,
etc.), jitter in the PWM comparator, line noise or what.
Tim
