would you not want R2 = 8R if possible?
if it was 9R for example, would the circuit not get unstable because of loop gain building up?
Regarding your circuit without buffering:If you are in the mood LvW, and have a fast method to derive this one that would be nice ;-)
I was wondering if there was a fast way to derive T(s)?
Like with the buffered one it became easy because once we consider one stage/cube it and then put the gain in there we dont need to use circuit analysis
do you know of a trick for non-buffered RC networks in sequence?
Hi Ratch - yes, here are the results of my "fresh start:":
With reference to your post#14 (calculation in blue):
Third line from the bottom:
* Left side of the equation is imaginary and right side is complex (imag. plus real).
This requires to set the REAL part of the right side equal to zero.
This would immediately lead to w=1/[SQRT(3)*RC].
* Alternative: Continuing your approach:
Shifting the left imag. part to the right side of the equation, we get: 0=Im + Re.
In the second line from the bottom you have set all the imaginary parts equal to zero (Im=0).
The result is given in the last line of your calculation.
* However, this is only the "first half of the story“.
Because the left side is zero you also must set Re=0.
Hence, we get as a second equation again: w=1/[SQRT(3)*RC].
* Finally, both equations must be fulfilled at the same time (because of 0=Re+Im)).
Equalizing both w expressions gives the condition: R2=8R. After inserting this requirement into
your w expression, we again get: w=1/[SQRT(3)*RC].
* Comment: To me, it was clear from the beginning that w cannot depend on R2 because only the
CR sections determine the phase properties of the loop gain. So - how can we interpret your
result (involving R2) - even if it is only 50% of the calculations?
If you - from the beginning - replace the ratio R2/R by the gain A you will see that A will be not
part of the imaginary part and, hence, R2 would not appear as part of your result.
Why this surprising fact?
Because the resistor R at the inv. input node of the opamp plays a double role: It is part of the
CR network and, at the same time. part of the gain determining resistor ratio. Therefore, it is
good to use the term A instead of R2/R (and not to combine this ratio with the other R terms).
* Final comment: The oscillation frequency is determined by the time constant RC only.
That means: The resistor R2 determines the gain only with the requirement: R2>8R.
Of course, the oscillation amplitude will rise until it is limited by the supply voltage or by any
additional non-linear part.
I can do it but it takes ages ;-(
Doesn't the factorization:
show that r2 is not a frequency determining component? It's only involved in the gain constant.
yeah thats my take on it too. the numerator will always be 90 degrees no matter what R2 is so I cant see how it changes the w required for 90 down below
Look at the 3rd line from the bottom of the attachment which says t = 1This is from your post #14, showing r2 being factored out of the expression for t;
r2 is involved in the 180 degree phase change, but its effect doesn't change with frequency, so the frequency of oscillation of the circuit won't depend on r2. Whether it oscillates at all will depend on r2, but not the actual frequency of oscillation.
Let's choose some values for components and plot the magnitude and angle of t. Let r=1000 ohms, c=.01 uF, and r2 = 8000 ohms for the blue plot, r2 = 16000 ohms for the red plot.
The magnitude changes when r2 changes from 8000 to 16000 ohms, but the phase angle does not change; the red and blue plots of phase are on top of each other:
You are plotting a term called "t". You should be plotting the equation of " t = 1" .What about the plots of phase vs. value of r2 shown in post #53, showing that the value of r2 has no effect on the phase vs. frequency of t?
I don't know how to plot an equation. I only know how to plot a mathematical expression, such as the t of the left side of that equation.
The relevant thing to plot here is the loop gain--the gain AB, what you called
"the output of A1*A2*A3" which is also t. When the phase shift of a signal traversing the full path is 360 degrees, that's the frequency where oscillation will take place, if the magnitude of the gain is suitable.
The phase shift experienced by a signal traversing that path does not change with changes in r2, so r2 has no effect on the frequency of oscillation.
Perhaps you could try a simulation of the circuit in question to see if r2 affects the frequency of oscillation.
Here's further mathematical verification that the phase shift of t does not vary with r2:
OK, here is my take on this. I set up an equation based on the assumption that the closed loop gain of the circuit had to be at least 1 in order to oscillate. I don't think you have any objections to that.
No - with one exception: It is the loop gain (not the closed-loop gain) which must be unity.
Then I solved for omega based on the assumption that the phase was 0 at the frequency of oscillation. I don't think you have any objections to that either.
No - of course, not - because this gives the first of the two necessary equations.
Now, you assume that the real part of that equation must also be zero. There is no way that a positive real omega number is going to satisfy both Im=0 and Re=0 at the same time.
No, I don`t "assume" this. The equation Re(T)-1=0 is the second part of the oscillation condition (our second equation for solving the two-unknown system).
Perhaps a complex number will, but that is not what we are looking for. For a unity feedback circuit like this, there is no reason to explore Re=0. The equation was already derived on the basis that the closed loop gain is 1.
No, that is not true. Setting only the imag. part to zero contains not yet any condition for the real part.
If you assume that a gain of 2 instead of 1 in the equation derivation, you still get the same w=1/[SQRT(3)*RC] for real terms, but a different omega value from the imaginary terms.
Yes - and exactly this is the reason we cannot rely on only one of the different results obtained from the two equations. We have to combine (equalize) both results. Only then we find the two unknowns (wo and A).
So , I aver that my last equation for omega, assuming Im=0, in post #14 is the correct one for omega in this particular phase-shift circuit. And, R2 affects both omega and the gain. Furthermore, requirements like im+Re=0, or Re=0 are bogus.
Ratch
