Hello
Please can you confirm that the Phase shift full bridge SMPS has many characteristics that have little to be desired? (when compared to a "plain" full bridge converter)
Our SMPS spec is...
Vin = 18 to 32V (28V nominal)
Vout = 34v
Iout = 25A maximum
I declare (in the way of a question) that the Phase shift full bridge smps has worse secondary sync fet snubber losses than a "plain" full bridge, because of the enhanced leakage inductance, which rings with the output capacitance of the secondary sync fets which needs snubbing....this is a serious disadvantage of the phase shift full bridge, since the amount of snubbing required will vary with the leakage inductance, which is generally a loosely toleranced thing....so one tends to have to use overly big snubbers at the secondary side.....surely its best to just do a "Plain" full bridge, and design it to get the minimum amount of leakage inductance in the transformer?
Page 20 of the LTC1922-1 phase shift full bridge controller datasheet confirms the high secondary snubber losses of the phase shift full bridge topology.
Also, it's known that even small amounts of leakage inductance in a "Plain" full bridge transformer mean that the actual duty cycle tends to be far higher than calculated. The phase shift full bridge converter does nothing to alleviate this problem.
Also, the phase shift full bridge converter, if designed with enough leakage inductance, will get Zero voltage switch_on of the primary fets...however, it does nothing to reduce fet switch-off losses....and switch-off switching losses are far worse than switch-on switching losses.
So really, especially with the increased secondary snubber losses that the phase shift full bridge converter brings, why would anyone want to do a phase shift full bridge converter rather than a "plain" full bridge converter?
Also, do you agree with my above points?
(the datasheets and research notes on this say nothing of the disadvantages of the phase shift full bridge topology)
LTC1922-1 phase shift full bridge pwm controller....
http://cds.linear.com/docs/en/datasheet/1922f.pdf
Our SMPS spec is...
Vout = 34v
Iout = 25A maximum
