Tim Wescott
It already does work!
Then why do you need any help?
If the circuit provides negative feedback at DC and has insufficient
phase margin at some frequency, then slapping in an inverter will give
you positive feedback, with some _very_ peculiar results. If you're
using an XOR or other mixer for the phase detector then it'll invert
automatically, and you won't be changing the gain/phase relationship of
the loop.
You've only designed with passive, single
ended filters?
No, a few more than that: Passive, single ended filters. Active filters
using op-amps, inverting, non-inverting, and double to single-ended.
Closed-loop control systems using several different types of
microprocessors, DSPs and DSPs roped to FPGAs.
I haven't used pneumatics, mechanical amplifiers, magnetic amplifiers or
dynamotors yet, but you never know.
From what population of PLLs are you drawing this "most"? If you'reMost active PLL filters are inverting.
working with the current crop of PLL-based synthesizers-on-a-chip then
using an inverting filter means you have to reverse the sense of the VCO
command/frequency relationship, or you need to flip a bit in the phase
detector someplace. If you're using an XOR phase detector then the
point is moot, of course.
