rowan194
I'm considering adding temperature regulation to a 12V portable fridge.
The circuitry doesn't appear to be much more than a hot/cold switch
which switches polarity to a peltier device. Will switching the device
on and off with a certain "minimum" period (to avoid rapid cycling) be
sufficient or should I use PWM?
Also, the peltier device inside the fridge has 4 wires - red&black,
plus two yellow. Any ideas what the latter two may be used for, perhaps
an internal thermostat?
Thanks in advance...
