I have no idea about anything electronic related but I think this forum should be overkill for my thing.
I bought fan controller to boost my GPU. I spend some time trying to set it up, I know how it generally work. If temperature exceeds given threshold by 1°C it trigger fan and try to drop it to 1°C below threshold. Temperature changes are monitored so if temperature is not decreasing then RPMs increasing.
I have four performance fans. Three of them around GPU card @1000RPM keep it at lower temp. with less amount of noise than when card is on its own cooler. However, if left alone in semi-auto one fan will reach limit before others and when this happen it spin up and temps are not increasing anymore. After ~1minute @3000RPM one fan will drop temperature 1°C below threshold.
As i wrote at the beginning I am looking more for McGyver style than proper solution. I think I want help making one temperature sensor for three lines. Perhaps I'm not good enough to ask proper question.
Thanks in advance
Thanks in advance
