mike
Thanks, that helps a lot.wind-up
Hi everyone,
I am trying to build a relatively high voltage-high current DC source.
The scheme is simple and uses no regulation (therefore no feedback
control). The scheme is as follows:
Utility mains supply => Variac => Three full wave rectifier bridges in
parallel => Huge capacitor bank => Load.
Variac: something similar to this one:
http://orgchem.colorado.edu/Technique/Equipment/Communityequip/Variac.html
Bridge: KBPC3510
Capacitor bank: 6800uF, 400V
I could not find a full wave bridge rectifier with a sufficiently high
current rating and therefore, I thought of paralleling three that were
readily available.
I start (slowly) increasing the output AC voltage of variac so as to
increase the DC supply to the load. However, the variac fuse blows-up at
around 10V AC output!
Paralleling three bridges may not be the most elegant way to build a
high-current DC source, but I do not understand what could cause the
fuse in the variac to blow-up. (Please note, everything works fine with
a single bridge rectifier. This ofcourse limits the amount of load
current I can draw out from the source.)
Thank you for your help and greetings for festive season. Wish everyone
a new year full of good health and prosperity!
Regards,
Anand
Thank you everyone for your replies. My replies to some of the posts:
1. I did check each one of the bridges and the capacitors for faulty
devices, incorrect polarity, short circuits and open. Didn't find
anything there. Also, the three bridges are identical.
2. I would doubt that inrush current is an issue here. Each time that I
ran this experiment, I was careful enough to increase the variac output
voltage very slowly. (Ofcourse, connecting an uncharged capacitor bank
to full output voltage of the variac would surely trip the circuit
breakers on the utility mains line.)
3. Not that it matters, but we use a 230V/50Hz mains supply with the
installation capable of handling 15A of current. (The variac fuse would
blow somewhere around 10V AC output with no load connected to the output.)
4. I am not sure, but I get a feeling that some of us reading this post
have "registered" this as "bridge blowing-up". No, it is the variac
fuse that blows-up. Infact, there was no heating on any of the bridge
(or capacitors for that matter).
I didn't know about the balancing resistor scheme. As already
indicated, it may not be the solution for this problem, but, thanks for
the idea, simple way of controlling current hogging.
I guess, monitoring the variac current with a clamp meter (or may be
even an oscilloscope may be a good idea).
Variacs are usually auto transformers and auto transformers work best
when the output is +/-30 % from the input (70 - 130 %) voltage. Trying
to get out only 5 % of the input voltage may cause some problems to
the autotransformer. If there are some advanced protection mechanism
on the variac, this might be triggered at such low setting, even if it
might OK around the input voltage.
voltage very slowly. (Ofcourse, connecting an uncharged capacitor bank to
full output voltage of the variac would surely trip the circuit breakers
have "registered" this as "bridge blowing-up". No, it is the variac fuse
that blows-up. Infact, there was no heating on any of the bridge (or
I didn't know about the balancing resistor scheme. As already indicated,
it may not be the solution for this problem, but, thanks for the idea,
I guess, monitoring the variac current with a clamp meter (or may be even
To understand why auto transformers are attractive with small up/down
voltage conversion (say +/- 10 % to +/- 30 %) , one should remember that
in an ordinary transformer, all the power is transferred through the iron
core, while in an auto transformer, only the power related to the voltage
_difference_ goes through the iron core, in this case only 10 % to 30 %.
You can think about the auto transformer as an ordinary transformer with
the primary connected to the input voltage and secondary with 10 to 30 %
of the input voltage. connect the secondary in series with the input
voltage and you get 10-30 % boost (in phase) or 10-30 % drop (connect in
antiphase). Only a small amount of the power goes through the iron core.
Trying to run an auto transformer (variac) at only 5 % of input,
practically all power flows through the iron core of the transformer,
might cause saturation and similar problems.
Huh?
In *any* transformer, all the primary current goes through the primary,
and all the secondary current through the secondary. The secondary amp
turns oppose the primary amp turns, resulting (in a perfect transformer
having no leakage inductance) in zero net amp turns hence zero flux.
Connecting windings in series makes no difference.
Where does the rest go?
You cannot saturate a transformer core with secondary amp turns. Even a
shorted secondary won't do it.
Saturation occurs where the magnetizing inductance (inductance of primary
with open secondary) allows enough current to flow to saturate the core.
That's why big current transformers, such as use in distribution equipment
buzz like hell if the secondary is O/C. That's a good danger warning.
COTS transformers are generally designed to run as close to saturation as
possible, at rated voltage and frequency, to economize on iron.
True for ordinary transformers with separate primary and secondary
windings.
It goes through the galvanic connection.
Depending on the variac setting, you can run hundreds of kW at 1:1
setting (limited only by the contact ratings), at 90 .. 110 % we are
talking about 10 % of the nominal power goes through the core, the rest
At 5 %, most goes through the core. possibly 1/20 of the nominal power
can be transferred through the iron core.
If, by that, you mean two inductors in series, how do you square that
with; voltage ratio=turns ratio, inductance ratio=turns ratio squared?
OP is that same eternal-september troll sicko harassing sed with stupid ignorant posts for quite some time now. Don't waste your time on "it."
Assume you have some AC point to point connection to a load.
Then connect a variac at 1:1 settings to the line. What happens ?
The actual power is still flowing to the load.
There might be some reactive (inductive) power flowing through the auto
transformer.
Changing the tap settings and more and more power will flow through the
magnetic core.
<LTspice listing snipped.>
For reality's sake, you need some series resistance in the source.
Why hide V1 parameters?
Yes. What value would you recommend for this simulation?
As JF stated, it is easy to see the parameters by simply right-clicking on
the source. If you want to see them on the schematic permanently, simply
click the box in the lower left corner "Make this information visible on
the schematic" after right-clicking the source. Easy.
