The resistor value could be a problem. If it's too big, there will be a lot of
voltage drop in the resistor, because of the base current. If it's too small, it
will get hot when its low side is grounded by the little mosfet. There may be no
value that works.
Your relays need 200 mA. If the NPN transistor has a guaranteed beta of 100, you
could need 2 mA of base current. Assume that when you have 12 volt power, you
want at least 11 volts on the relays; the transistor drops 0.7, so that leaves
0.3 for the resistor. The resistors has to be 150 ohms. Now let the supply go up
to 18 and turn on the mosfet. The current through the resistor becomes 120 mA
and it dissipates over 2 watts.
If you think the relays will operate with less voltage, use a bigger resistor,
and it might work. But it's a messy compromise.
John Larkin Highland Technology Inc
www.highlandtechnology.com jlarkin at highlandtechnology dot com
Precision electronic instrumentation
Picosecond-resolution Digital Delay and Pulse generators
Custom timing and laser controllers
Photonics and fiberoptic TTL data links
VME analog, thermocouple, LVDT, synchro, tachometer
Multichannel arbitrary waveform generators
