L
lj_robins
I have a Maytag Gemini stove model # MER6872BAW, about two weeks ago
everyone started noticing that nothing was getting fully cooked in the
upper oven. We use the upper oven a lot so I figured it was either the
sensor or the element.
I stuck a fireplace thermometer in the upper oven just to make sure
everyone wasn't going crazy, the temp on the oven's digital display said
400 degrees, the fireplace thermometer said 310. I stuck the thermometer
in the lower oven, the display and the thermometer both said 400 degrees.
Figuring that it was the sensor I replaced it, the upper oven still
acted the same. I was able to find a schematic for the oven on
Sears.com, the sensor goes straight back to a connector on the circuit
board inside the control panel.
The new and old sensors both read a little over 1000 ohms, the sensor
connectors for both lower and upper ovens are both reading 5.15 volts
DC. My only guess on this is that there is something wrong with the
circuit board. I looked it over all the parts look fine, no burnt
resistors, none of the capacitors are bulged at the top, no popped
transistors.
The oven did give me a code F9-3 while I was working on it which decodes
to: "Check for obstruction in door lock mechanism" (there is nothing in
the mechanism). Oddly enough six months after we had this stove it gave
that code with no warning at all, it gave another code too but I do not
remember that is was. A month later it did it again, then no problems
with it at all for three years until too weeks ago.
Anyone have any suggestions on what might be wrong?
transistors.
