Hello Jim,
Thanks - I've got an old Minolta 300 that probably has the same fault.
I've not looked at it. Is is easy to get at the offending component?
It is really easy. Turn the camera off, remove batteries and place it
upside down onto a white towel in case a screw falls down. You don't
want any of these to disappear in the carpet, it's unlikely to ever find
a spare.
Remove the four little screws and black plastic bottom cover. Now you'll
see an electrolytic on the side. That's the one. Note which side is plus
(on mine it was towards center of the camera). Carefully unsolder the
capacitor. It helps to bend down the flex with a tooth pick so each leg
comes off without applying heat for too long. Replace the capacitor with
the type I mentioned. I bent its legs inwards and stripped off that
little black SMT carrier to make it even smaller.
Place cover back on. The smaller screws with machine thread go inside,
the longer ones with the coarser thread on the outside (those are a bit
tougher to turn).
That's it. It took me an hour to find a suitable cap, a few days for
Fedex to get it here and about ten minutes to actually do the repair.
Regards, Joerg
