OT: Acceptable temps from a chest freezer
Jeßus
Just bought a F&P chest freezer to replace an older chest freezer with
thermostat stuck on flat out (I'll look at replacing the thermostat
now that I have the new freezer to put the contents in).
I have the thermostat turned up to 5 (out of a maximum of 6) on the
F&P, yet the internal thermometer hasn't dropped below zero, or maybe
*just* below zero. It's in the exact same location as the old one,
which sat at about -20C using the same thermometer (keeping in mind
the thermostat was stuck on flat out).
http://en.wikipedia.org/wiki/Refrigerator#Freezer says average freezer
temps should be -23 to -18 °C.
Personally I don't think zero degrees is good enough.
Opinions, please?
Jasen Betts
Is "5" hotter or colder than "3" ?
Opinions, please?
Zero degrees only if it's Farenheit.
Most packaged frozen food specifies at or below -18°C
Bob Milutinovic
Opinions, please?
Just some thoughts...
1. Dedicated freezers (chest freezers in particular) can take up to a week
to get to their optimal working state. A bit like the four-cylinder Prado
some bloke mentioned here not long ago - the tiny motor'll get the job done,
just give it time.
2. You need to have food in there; if you've got it running empty, it'll
likely never get to its proper working temperature. The more food you have
in there, the colder it'll get (strange but true!).
3. F&P don't have the world's best QA department. I bought a brand new F&P
fridge many years ago and had to get their technician out twice in the first
three weeks.
Albm&ctd
Opinions, please?
I had all sorts of trouble with our F&P fridge from new, then bought another
thermostat and fitted that to make a fridge that has been faultless even since,
like it's 17 years old now.. so from this I'd suspect you have a similar
problem.
Al
Noddy
Opinions, please?
I don't think it is either.
We have a F&P vertical freezer and while I don't recall if it has an
adjustable thermostat it sits constantly on -19 degrees. Similarly, the
freezer compartment of our Westinghouse fridge does have a thermostat
and a built in temp gauge, and we have that set to -18 degrees which is
just right for ice cream.
Noddy
F&P fridge many years ago and had to get their technician out twice in
the first three weeks.
Agree with that.
We bought a F&P dishwasher and it ran for 6 weeks before it shat itself,
and it took them 2 months to do anything about it. In the mean time I'd
replaced it with a Bosch and sent the F&P back to F&P for a refund.
The Red Krawler
F&P is terrible.
Yes, I would expect to see even the most basic domestic chest freezer
hit -20°C (... eventually).
You've been a sold a lemon most likely. Personally I'd see this as a
good thing if you can take it back and get a refund. Find a Kelvinator /
Westinghouse / Whirlpool that's been made in Australia (just check the
nameplate - some models are made here, some overseas) and you'll get
much better performance and longevity.
Bob Milutinovic
The Red Krawler said:
F&P is terrible.
You've been a sold a lemon most likely. Personally I'd see this as a good
nameplate - some models are made here, some overseas) and you'll get much
Ummm... Unless something's drastically changed over the past few years,
you'll find that F&P refrigeration products are made in Queensland.
Bob Milutinovic
kreed said:
I think you will find that it was closed down
http://en.wikipedia.org/wiki/Fisher_&_Paykel
According to this, they closed their Cleveland, QLD Australia plant in
2008.
reliability products with their dishwashers are also mentioned further
down the page.
"Oh my God, they killed Cleveland!" "You Bastards!"
So now there's literally _no_ reason to pay their extortionate prices.
Baron
Rheilly Phoull Inscribed thus:
Hmmm, 1 freezer 'stat u/s, 1 freezer 'stat OK low on gas.
What to do ??
Rheilly P
Return it as faulty ! I agree the lack of gas. Probably a micro leak
in a pipe joint !
A few years back I bought a new freezer. It was fine for about 6-7
months but I had to keep turning up the stat to keep it cold enough.
At 10 months the stat was full up and the compressor was running
continuously.
We complained to the manufacturer who sent an engineer out, who said it
had lost its gas, he re-gassed it. 12 months later we were in the same
situation again. We again complained to the manufacturer who said
sorry its out of warranty. So we said that we were going to sue them !
10 days later we issued CCP against the company. A week after that we
had a new freezer and repayment of the CCP costs. No other
compensation though. The replacement freezer is absolutely fine, just
as the original one should have been.
HTH
Jeßus
Err, I discovered the fridge thermometer I'd used must have had a
temporarily stuck dial... :)
Tried another thermometer and the freezer is at about -25°C, so all is
well. The original thermometer now agrees as well... must've jolted
something loose again I guess.
Thanks for the replies.
Jeßus
problem.
All sorted out now - dodgy thermometer! My last (new) chest freezer
was a F&P, never had trouble with that and only sold it at the time
because I didnt need one foe a few years. But it's such a minefield
these days, picking between brands of whitegoods. They change things
all the time, so you never know.
Jeßus
F&P is terrible.
Sorted out the isssue - dodgy thermometer!
Problem is these days there's such a limited range in chest freezers
available, seeking out a specific size really limits your options.
And not all brands or models are sold down here in Tassie, which
limits it even more.
The F&P is the only one with an internal light, which I have to admit
swayed me a bit, plus the one I chose was heavily discounted -
superceded model I think.
Jeßus
The F&P that it replaced had problems with rust, and one shelf broke
in half after about 2 years, and
when examined, the plastic shelf design was very poor in my opinion.
I wouldn't buy that brand again, if I was looking long term
My 3 y/o Electrolux fridge has the same problem with the internal
plastics - brittle as all hell. I'm NOT impressed about that.
It's of the 'upside down' type, the two front covers for the freezer
drawers both broke ages ago and many cracks in the fridge section as
well.
F Murtz
The said:
F&P is terrible.
In my case,if I want an ice maker L&P are the only maker with one less
than 800mm wide which is my available space.
The Red Krawler
F&P have never been any good, regardless of where they were made. And
definitely not worth paying a premium for.
I wasn't actually aware that they were ever made in Australia (I thought
they were a Kiwi mob).... but regardless my comment about being "made in
Australia" was purely for the Kelvinator / Westinghouse / Whirlpool
brands that have a combination of Australian-made and overseas-made
products. The Australian-made stuff is good gear. The overseas made
stuff is not so good. Prices usually vary accordingly. It's definitely
worth paying the small premium for the locally made product.
The Red Krawler
Glad you got it sorted.
By the way, why not use a digital thermometer? You can pick up one with
basic logging (max high/max low recording, alarm at specified high/low
temps) for cheap and the single AAA battery will last you for like a
year... which makes a 4 pack of AAA batteries cover the life of a F&P
fridge ;)
I use one that looks very much like this:
http://www.ebay.com.au/itm/Digital-...20964073898?pt=AU_Gadgets&hash=item33727c31aa
.... and it works a treat.
Jeßus
That's normally my approach - I'd rather pay a bit more for quality.
But I'm a bit limited on options due to where I live when it comes to
white goods. Fingers crossed this freezer behaves itself.
Jeßus
fridge ;)
Looks good, especially for the price. I have a similar digital
thermometer for my Waeco, but it doesn't have any temperature alarms
like the one in your link. I might just buy one, thanks.
Bob Milutinovic
Just as a matter of interest, are there any markings (there should be, on
the specification plate) indicating where it was made?
I'd be interested to know where they've relocated their refrigeration plant
to.
