oscilloscope without wire ground
Tobias Gadelha
Em terça-feira, 30 de julho de 2013 02h01min58s UTC-3, Phil Allison escreveu:
"Tom Biasi"
** Of course they are not the SAME !!!!!!!
Neutrals ARE current carrying conductors.
Safety grounds are NOT, until a fault condition arises.
Make your point clear.
... Phil
Phil
I'm from Brazil and here N= Neutral ; L1 =220V (-120º); L2=220V (0º) and L3(+120º) therefore L1 in oscilloscope will be GND and L2 the prove.
Is it possible with the wire groud conected in the jack?
Phil Allison
"Tobias Gadelha"
** My god, the fool IS mucking about with 3 phase power !
Is it possible with the wire groud conected in the jack.
** Question time:
Have you got a dual trace /channel scope with "invert" function on one
channel ?
Do you have two 10:1 probes ?
If so, others have given you the answer already.
BTW:
3 phase power is VERY DANGEROUS !!!
Beginners should NOT be touching it.
.... Phil
Tom Biasi
"Tom Biasi"
... Phil
I made my point clear Phil.
You said, "Neutral conductors are always linked to ground at the service
box."
I said," In the USA neutral and ground are "usually" connected at the
service box but not always."
That's clear enough.
No need to go beyond that.
Tom
Phil Allison
"Tom Biasi"
** Clear as mud - pal.
box."
** NO it is NOT !!!!!!!!!
** It must be connected to ground somewhere - or else it is simply NOT a
neutral.
Ever see the movie "Groundhog Day" ??
.... Phil
Tobias Gadelha
Em domingo, 28 de julho de 2013 15h49min54s UTC-3, Tobias Gadelha escreveu:
Is there any risk to use oscilloscope without wire ground? Because with wire ground there is a short circuit when I use GND on the line.
ok people, resolved. thanks
