I just built mysf a little charger circuit for a super cap, even a 2w 22ohm resistor is getting hot delivering under 300ma (taking forever for a 400f cap lol)
but, the question is.. i used a comparator vs an opamp, and when the voltage is reached the output pin drops to gnd voltage, most opamps sources current at a specified voltage (eg when it hits x 5v is spit out) so i had to use pnp's no problem
Without using an opamp can anyone name a voltage comparator which i can use with npn's where it sources and not sinks ?
Thanks (i have more npn than pnp)
