OP AMP voltage multiplier
Ahmed Samir
Hi there
is it possible to realize a four quadrant voltage multiplier-for audio
signals- using an op amp or two?if so how and if it's not possible what's
the easist way to do it??
thanks very much
ahmed samir
Tony Williams
what's the easist way to do it??
AD633JN from Analog Devices. For best thd, use the
Y-inputs for the audio, and keep the ac input signal
below about 5Vrms.
Bill Sloman
below about 5Vrms.
The AD633 is clearly what the OP needs, but it isn't the op amp that
he is asking for, and it is probably worth mentioning that a
four-quadrant multipler is a non-linear device, and op amps - as such
- aren't designed for non-linear applications. After all, this is
cross-posted to sci.electronics.basics where you can't assume any
background knowledge of electronics.
Rene Tschaggelar
Ahmed said:
Hi there
OpAmps cannot do this, have a look at the multiplying DACs.
Rene
Bob Masta
Hi there
Not possible with an ordinary linear op-amp. The usual
approach uses an array of matched transistors (plus a
couple of op-amps). Try a Web search for 'Gilbert Multiplier'.
There are also Operational Transconductance Amplifiers
(OTAs) like the CA3080 and LM13600 that are often used
to create multipliers, but usually just 2-quadrant..
Depending on exactly what you are shooting for, there are
a number of tricky approaches, including diode ring (bridge)
multipliers, FETs as voltage controlled resistors, pulse width
modulation, log-antilog, etc. Tell us more about your application and
maybe we can pick out the simplest/best approach.
Bob Masta
tech(AT)daqarta(DOT)com
D A Q A R T A
Data AcQuisition And Real-Time Analysis
Shareware from Interstellar Research
www.daqarta.com
V
Vladimir Vassilevsky
Ahmed said:
Hi there
Everything is possible, but probably not worth to.
The accuracy and the distortion are going to be about 1% best to best.
I would advise to use DSP instead of messing with analog.
Vladimir Vassilevsky, Ph.D.
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
K
Kevin Aylward
I reason your opinion is a obviously a bit biased here. I would guess
that the poster wants a *simple* solution. i.e. one without spending 6
months with development systems.
To the poster. Analog Devices SSM audio VCA parts are pretty good. They
used to be PMI ones, which used to be...
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
Precious Pup
Bill said:
... and it is probably worth mentioning that a
four-quadrant multipler is a non-linear device,...
And it is probably worth mentioning too that BS has never taken a Signals and Systems course, along with never
taking ECON101.
Show the following system to be either linear or non-linear:
The System
in | /¯¯¯\ | out
x(t) O--------( X )---------O y(t)
| \___/ |
| O |
| cos(w_c·t) |
Included and inside the system is a "4-Quad" multiplier.
Bonus points: Show the system to be either time-invariant or not.
Ben Bradley
With a diode 'ring modulator', maybe...
You're just trying to drum up DSP business, aren't you? ;)
MC1496 from onsemi.com, cheap, usable, still available in DIP (!),
less distortion than a diode ring modulator, and the company only used
to be one other company...
Jim Thompson
taking ECON101.
[snip]
How appropriate, "BS" ;-)
But "BS" has taken all the Commie and Socialism courses ;-)
...Jim Thompson
Bill Sloman
taking ECON101.
[snip]
...Jim Thompson
Ah. More jokes from primary school. Concentrate on electronics, Jim -
you are pretty good at that.
Oddly enough, I've not taken any Commie or Socialism courses either -
as with electronics, if there has been something I need to know I go
off to the library and read about it.
I used to be embarassed about my lack of formal qualifications, but
after you have supervised a few new graduates you get some idea of how
little of their coursework actually sticks, and I stopped worrying. It
never worried the IEEE at all.
I wonder if Peurile Pup has ever published anything in a refereed
journal - let alone had it cited.
Ben Bradley
Ahmed Samir said:
i want to realize a frequency inversion circuit
audio signal from 300 to 3000hz, and the single tone at 3000hz
Oh, you want to make a "Voice Scrambler." This crude ASCII block
diagram should demonstrate it:
IN --->[300Hz-3kHz bandpass filter]--->[4-quadrant multiplier]--->out
3.3kHz sine wave
For the bandpass filter, cascade a simple R-C 300 Hz high-pass with
a two-pole or three-pole low-pass filter from Lancaster's "Active
Filter Cookbook."
This circuit will work for both encoding and decoding.
Precious Pup
taking ECON101.
[snip]
...Jim Thompson
Now that's an accomplishment. You can get deluded just fine without bothering with school.
I used to be embarassed about my lack of formal qualifications, ...
It isn't your formal qualifications you should be embarrassed about. You should simply be embarrassed about
being a persistant dumbass.
but
Retard, I don't claim to be original, creative, smart, clever, and whatever else you fantasize yourself to
be. I don't really care. I try to get folks to give me money in exchange for effort/labor -- that's about
it.
Let me publish more right here for you:
Compare and contrast the two systems.
The System
in | /¯¯¯\ | out
| \___/ |
| O |
| DC=2 |
The System
in | |\ | out
x(t) O--------| >-------------O y(t)
| Op-amp set to |
| a gain of two |
Are these systems linear?
