Has anyone knowledge or experience concerning electrolytic capacitors in AC circuits?
Of course you have the specially made non-polarized (NP) versions, but they are expensive and don't go high with capacity.
In Wikipedia, it's stated that the reverse voltage should not exceed 1 to 1.5V. Still I have seen published circuit diagrams with the configuration of two electrolytic capacitors connected with the minus (or plus) poles together and used in AC circuits (see diagram).
As I understand, what usually takes place when an electrolytic capacitor is getting problems, is that the electrolyte starts boiling (evaporating gases) and the thing explodes in a more or less spectacular way!
Could it be that it's possible to use electrolytic capacitors in AC circuits, as long as they don't heat up "too much" (like in normal DC circuits with much ripple)?
Could it be that the changing of polarity would protect them from being chemically destroyed and allow them to be used at much higher reversed polarity voltage?
Has anyone read about this or made some own research?
(please not just the "you-shouldn't-do-that-answer")
Thank you for answers!
p.s. Once I really got shot by an electrolytic cap. One of my dear children had helped me to solder some components on a PCB. When I tested the board, one small electrolytic capacitor had been reversed polarized. Obviously the thing didn't have a venting system, but came flying like a bullet on my hand. Luckily I was only bruised, but I can tell you it really hurt.
Here a guy showing what you (officially) shouldn't do to these things: exploding capasitors
