V
Vladimir Vassilevsky
There is a loop receive antenna. It is the LC circuit with the Q at
the order of 100. It has a high resonant peak. The frequency and the
amplitude of the peak are sensitive to the component values,
temperature, particular parts, etc. I would like to damp the Q down to
something like 10, so the parameters would be much more stable and
predictable. This can be done by adding a series or a parallel resistor
to LC.
However the SNR of the antenna drops approx. proportionally to sqrt(Q)
due to the thermal noise of the damping resistor. I wonder if it could
be possible to implement the noiseless damping. Cooling down the
resistor is not an option.
One idea is to switch the damping resistor on-off with a high frequency
and a low duty ratio. Or to switch or vary the value of the capacitor so
the resonance peak will be dithered. It has many side effects, though.
Any ideas, suggestions?
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
to LC.
