No. You need a temperature sensor to reliably prevent a temperature rise above 70 C.
Here is one that opens at 180 F (~82 C). Just wire it in series with the heater and it will remove power when the surface reaches the switching temperature.
This sensor is based on the Texas Instruments patented
Klixon bi-metallic switch sensor. The patent is long expired so anyone can make them now. The device consists of two dissimilar metal coin-shaped pieces, concave stamped, and welded at the edges, thus forming a bi-metallic switch. It can be depressed by a spring on the convex side to allow it to "snap" to the other position at a certain temperature, where the formerly convex side now becomes concave and the formerly concave side becomes convex. It then remains in this switched state until the temperature decreases a sufficient amount to cause it to "snap" back to its original state.
Some Klixon sensors do not reset. These are used in appliances as fail-safe cut-outs. If you decide to acquire and use one, make sure it automagically resets back to the closed-circuit condition when the temperature drops below the trip point temperature.
Years ago at trade shows, Texas Instruments kept of bowl full of these gadgets to hand out free. They were designed to transition states at nearly body temperature, so you held one tightly in your hand to warm it up and then, using your thumb, manually switched it to the now-stable "hot" state. Then you laid it on a flat surface and stepped away, waiting for it to cool down to room temperature. This took several seconds, sometimes as long as a minute, but eventually it went "snap" and bounced up into the air when it cooled sufficiently... often startling passersby, which no doubt was the intent. Fun toy, but I have never seen them commercially marketed and the few I had have long since disappeared.
