Sorry, I originally posted this on the wrong forum...
Hi, I'm very new here, so please bare with me.
I'm making a lab incubator from cheap materials. The housing is common board from Home Depot. I have an electronic thermostat unit with a 110V/10A relay I've wired to it and was trying to run a 5W tape heater with it. It didn't give enough heat. Now, I'm looking into using a NiChrome wire heating element that I construct.
The problem I have is I'm not sure if my circuit will work. I plan to use a 120V to 12V center tapped step down transformer (450mA) I got from Radio Shack to drive the element. From what I've been able to conclude, I could either use the 12V or 6V CT directly with a 6 inch 32 gage NiChrome wire to produce a heat of approximately 290 degrees Fahrenheit. Here's my concerns:
Is this approximation of heat correct?Since this is low ohms, will this damage the transformer?Will this heat excessively, resulting in burning or scorching the wood, when suspended 1 inch from the wood?
If you have alternative ideas, please let me know. I'm just not thrilled with the idea of making due with prefab heating elements because whenever I do, I seem to waste money like I did with the tape heating unit.
I've included an image of the incubator. It uploaded sideways.
...And yeah, I know I cracked the housing. I was too lazy to predrill for some of the screws.
