Yes, that's the important factor.
I'm sorry, I don't understand the question. Can you post schematics of the circuits involved?
Sorry, these are ready-built devices which plug into the Atari ST such as this device which plugs into the serial (modem) port, and this device which plugs into the cartridge port (left side of the computer). They both supply additional MIDI IN and OUT ports.I don't have the schematics for them, but I have opened them up as I'm curious to see what's inside. I meant that by accessing the circuitry I could possibly tap into the MIDI ports and get a signal which could be fed to the (standalone) LED pulse stretcher circuit, but assuming there's no built-in MIDI THRU (as with the original ATARI ST circuit we've already looked into) I guess I need to use the THRU version of the pulse stretcher, correct?
You don't need optocouplers unless you need isolation between the 0V rails of the two circuits. Here's how to use the pulse stretchers without isolation, assuming they are powered from the Atari's +5V rail. I've shown the mod for the bottom one; repeat it for the top one.
Ah, yes, I was a bit unsure about that one. So the rule is that you only need an optoisolator whenever a signal is received from another device, and this isn't the case here of course?
Let's see if I've got the schematic right (I've also added the trimpot as in the "THRU version", hoping that's right too, by replacing the RT1/RT11 resistors with the trimmer and 1K protection resistor in series. I've also changed the value of CT1/CT11 from 0.1uF to 330nF as in the THRU version).
And yes, I'll be using the Atari ST power supply to power the LED pulse stretcher circuit.
And here's the standalone circuit on its own, with the trimpot replacement as above:
And the trimpot/portection added to the THRU version of the pulse stretcher:
Good idea!That looks right to me. There's one change I should at least suggest to you. With the present circuit, if you turn the RT1 trimpot fully anticlockwise, i.e. shortest possible LED blink, it is possible that Q1 could be damaged because there is no resistance to limit the current flowing through it. To avoid this potential problem you can add a small resistance, e.g. 1k, in series with RT1. Drag RT1 down closer to the 0V rail and break the wire from the top end (it's marked "3") of RT1 to the rest of the circuit (Q1 drain, CT1, and the 4070 input) and insert a 1k resistor in the break. That will protect Q1 if the trimpot is ever turned fully anticlockwise.
Here it is again with those modifications:
Are you going to prototype the circuit on a breadboard first? Just wondering.
Actually I recently did buy a couple of breadboards which I haven't used or figured out yet, so that might be a good idea. I've been away from this hobby for years, so time to start again and relearn a lot of things. I also haven't quite figured out the etching stuff, and with limited time on my hands I see this is going to take time, but I'm getting there. The Eagle software is of great help, but with the free version it's limited to small boards and with the 17 MIDI connectors I'll likely exceed that limit. My suggestion is then to build the MUX/LED circuitry on one board, then have the MIDI ports on another board, and since the same circuit is repeated 16 times I could just print out a few pairs to a high resolution image file, then join them together in Photoshop to actually build the entire 16 IN + 1 OUT board. Will there be a problem with signal loss/degrading if I attach the two boards together with connectors/thin wires as opposed to just having one huge board with everything attached using circuit traces? Obviously the wire lengths won't be more than a few cm.
