First chance i will get i will lay out a schematic of the circuit you need. just get the components with the values i will use. As far as resistors , capacitors and the LM555 any brand will do.
I was thinking that you will probably not be able to feed the pulse directly to the button pins. You will have to drive a relay from the output of the LM555 and connect the relay where the button was.
